firebird hood
ok heres what i got some po cut a hole in the middle of my 75 formula's hood is there an easy way to patch this an make it look ok
1 Attachment(s)
A few thing's you can do is, buy another hood if you can find one. Buy an after market hood or, get a bolt on cowl to cover it up. I think the formula's dual ram snorkle hood looks awesome. If someone cut a hole in this original Formula hood they should be hung from a tree and flogged! If it doesn't have this hood, it isn't original anyway so I wouldn't bother and get an after market replacement. I doubt a patch would last very long and will eventually crack from the abuse of opening and closing all the time. JMO :D |
im shure my hoods factory just with a 6inch hole in middle of it
when i got the car it was set up for a sb chevy an weired cable's to limit the down travel on the lower a arms. i put it back together with ra pont 400 an a 4speed |
Does it have the dual scoop hood on it WITH the 6" hole?
the hood has the functional dual scoops if i had the right filter housing. the hole in the middle of the hood is set back some from were the pont 400's carb is idk if they set the sb chevy closer to the firewall when i got it didn't have the motor or trans but the sb chevy mounts were there an welded to the crossmember wasn't fun getin those off
wish my camera wasn't broke or id put some pix up |
It is possible to weld a piece cut from a stock Firebird hood into the hole to repair it. will require good welding skills and bodywork, it would be best to take it to the best oldtime bodyman in your area and pay them to do it if you are serious about saving it.
Not the place you want a rookie or less experienced welder doing the welding, very easy to warp it and ruin it. |
Cole |
87fubar is your hood fiberglass?? Cole |
yes its fiberglass
A good glass man can fix that and you will never know it had a hole in it. :cool: Cole |
would it need a complete new coating not shure what you'd call it or would it be more of a paint
Fiberglass :thumbup: Just a matter of patching the hole, smoothing the work, priming and block sanding the entire hood and then Epoxy priming and painting. You could leave it in Epoxy primer if you want the flat black look.
It won't need to be re-gelcoated. If you know how to worjk with fiberglass it is a piece of cake, your hood can be saved. Bodyshop or even a Marina(boats are fiberglass) could help you. |
good to know it can be saved an i wont have to look for another
| All times are GMT -6. The time now is 06:45 PM. |
