firebird hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2011, 05:04 AM
87fubar's Avatar
firebird hood
ok heres what i got some po cut a hole in the middle of my 75 formula's hood is there an easy way to patch this an make it look ok
Old 02-24-2011, 08:24 AM
sqzbox's Avatar
My pipes are my music
You could find a way but it probably wouldn't justify the cost and labor.
A few thing's you can do is, buy another hood if you can find one.
Buy an after market hood or, get a bolt on cowl to cover it up. I think the formula's dual ram snorkle hood looks awesome. If someone cut a hole in this original Formula hood they should be hung from a tree and flogged! If it doesn't have this hood, it isn't original anyway so I wouldn't bother and get an after market replacement. I doubt a patch would last very long and will eventually crack from the abuse of opening and closing all the time. JMO
Old 02-24-2011, 09:32 AM
87fubar's Avatar
im shure my hoods factory just with a 6inch hole in middle of it
when i got the car it was set up for a sb chevy an weired cable's to limit the down travel on the lower a arms. i put it back together with ra pont 400 an a 4speed
Old 02-24-2011, 02:03 PM
sqzbox's Avatar
Does it have the dual scoop hood on it WITH the 6" hole?
Old 02-24-2011, 03:56 PM
87fubar's Avatar
the hood has the functional dual scoops if i had the right filter housing. the hole in the middle of the hood is set back some from were the pont 400's carb is idk if they set the sb chevy closer to the firewall when i got it didn't have the motor or trans but the sb chevy mounts were there an welded to the crossmember wasn't fun getin those off
wish my camera wasn't broke or id put some pix up
Old 02-24-2011, 05:09 PM
ericnova72's Avatar
More for Less Racer
It is possible to weld a piece cut from a stock Firebird hood into the hole to repair it. will require good welding skills and bodywork, it would be best to take it to the best oldtime bodyman in your area and pay them to do it if you are serious about saving it.
Not the place you want a rookie or less experienced welder doing the welding, very easy to warp it and ruin it.
Old 02-24-2011, 05:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 couldn't agree more Eric. I had a buddy that had his challenger hood repaired and it looked good for a year or so and that's being nice because really you could notice where it was repaired at if you looked and didn't have to look hard either. There are some people out there that can do this and it will really look good but it might cost a bit.
Cole
Isn't the dual scoop Formula hood made out of fiberglass??????
Old 02-24-2011, 05:23 PM
ericnova72's Avatar
More for Less Racer
Now that you mention it, I don't know . I know the '70-73 is, and the '77-81 is metal, but IDK about the '74-76 years. If it is fiberglass that makes it even easier to fix.
Old 02-24-2011, 05:41 PM
eloc431962's Avatar
Wiki Edits: 37
Hummm, never thought about that either. You would think the op would know that wouldn't you ?
87fubar is your hood fiberglass??
Cole
Old 02-24-2011, 06:07 PM
87fubar's Avatar
yes its fiberglass
Old 02-24-2011, 06:23 PM
eloc431962's Avatar
Wiki Edits: 37
yes its fiberglass
Be a whole lot easier and better to fix IMHO
A good glass man can fix that and you will never know it had a hole in it.
Cole
Old 02-24-2011, 07:04 PM
87fubar's Avatar
would it need a complete new coating not shure what you'd call it or would it be more of a paint
Old 02-24-2011, 08:51 PM
ericnova72's Avatar
More for Less Racer
Fiberglass Just a matter of patching the hole, smoothing the work, priming and block sanding the entire hood and then Epoxy priming and painting. You could leave it in Epoxy primer if you want the flat black look.
It won't need to be re-gelcoated.
If you know how to worjk with fiberglass it is a piece of cake, your hood can be saved. Bodyshop or even a Marina(boats are fiberglass) could help you.
Old 02-24-2011, 09:07 PM
87fubar's Avatar
good to know it can be saved an i wont have to look for another
fiberglass hood repair 72 pontiac firebird. AndersonRacing44 Body - Exterior 1 11-25-2010 08:03 AM
Hood pins verse stock hood latch 62440 Body - Exterior 3 08-23-2010 09:30 AM
Firebird hood hinge interchange JoshF Body - Exterior 3 04-01-2009 07:03 PM
New Firebird hood hitting the market soon! drewhelm Body - Exterior 7 02-25-2006 04:59 PM
New Firebird hood coming soon! drewhelm Hotrodders' Lounge 0 02-16-2006 04:07 PM
