Firebird hood hinge interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2009, 07:23 PM
Well, I went to bolt my hood on today and it looks like the hinges that came with the car are not actually for the car since the back of the hood sits high when it is closed. Are there any other cars with hinges that will interchange with a 68 Firebird so that I can broaden my search and hopefully find a set?
Thanks,
Josh
Old 04-01-2009, 05:16 PM
I just put and after market hood on 68 firebird. to get the back of the hood down, loosen the bolts that hold the hinge to the fender then open the hood all the way .the hinge will rotate up causing the hood to sit down more in the back.the hinges are most likely ok they need adjustmens. and as you get the hood down you will have to loosen the bolts that go from the hinges to the hood to move it fore and aft.
Mike
Old 04-01-2009, 05:47 PM
Mike
I'll give it a try, I did not put too much effort into it because the holes looked bastardized enough I figured they were from a different car with a different hinge. Thank you.
Old 04-01-2009, 07:03 PM
It looks like you saved me $80. Thank you.
Still fine tuning though.
Front hood hinge attachment murphturf Body - Exterior 4 06-16-2006 01:35 PM
Hood hinge problems! PLEASE HELP! elvisjer Body - Exterior 2 01-23-2006 05:23 AM
Hood hinge problems. Help! elvisjer Body - Exterior 1 01-15-2006 09:55 AM
32 Highboy hood hinge & latch kits Highboy Therapy Introduce Yourself 1 12-17-2004 08:40 AM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
