Firebird leaking rear brake fluid. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2011, 05:58 PM
bigdog7373's Avatar
Of course it's fast
Just found out yesterday that the rear brakes in my 78 dont work. Checked the master cylinder and the rear resovoir is empty. I topped it off a few months ago. Is this common on gen 2 f bodies? Where should i start looking for a leak? Thanks in advance.
Old 02-19-2011, 06:05 PM
poncho62's Avatar
Wiki Edits: 5
Probably a rusted out brake line.........
Old 02-19-2011, 06:07 PM
bigdog7373's Avatar
Of course it's fast
There's no visible leaks anywhere, thats the thing. I would thing that you would be able to see if there was a bad line somewhere.
Old 02-19-2011, 06:39 PM
vetteman2's Avatar
look and see if the master cylinder is leaking, and running down the brake boster
79 Firebird rear disc emergency brake adjust retiredusncustoms Suspension - Brakes - Steering 6 01-18-2011 12:06 PM
stall leaking fluid no name Transmission - Rearend 4 10-22-2007 07:43 PM
1968 Firebird Rear Disc Brake Conversion TORI1 Suspension - Brakes - Steering 3 07-21-2006 02:17 PM
Will rear parking brake calipers from 82-85 firebird fit my 68 Camaro? shockers69 Suspension - Brakes - Steering 1 04-19-2004 08:27 PM
fluid leaking out servo... bstm23 Transmission - Rearend 3 01-22-2004 05:41 PM
