Firebird Rocker Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2012, 03:01 PM
rusthater89's Avatar
What does the inside of a 1978 Firebird rocker panel look like. Is it simply a box or is it the kind that has a piece of metal in between?
Old 08-21-2012, 07:46 PM
bigdog7373's Avatar
Of course it's fast
Your profile picture is classic.
Old 08-22-2012, 09:47 AM
put up or shut up
never did one for that year but there's usually an inner and outer rocker. Might sound like a lot but it's a pretty bare minimal structural design. In newer cars you might find rocker covers and the outer sheet metal isn't even classified as an outer rocker, the outer rocker would be underneith, then there's an inner rocker too. So for sure on classic cars it's a lot less to deal with.
Old 08-22-2012, 11:44 AM
LOL, My girfriend had an evil hamster so I got the fruit.
Old 08-22-2012, 11:47 AM
Looking at it I just see a few spot welds. So I figure I could drill them out and when I am done fixing it up I can just weld it back in place. The top part however looks like it is an extension of the floor.
My garage is a mess from sandblasting. When I am done i'll post some pics of it.
Old 08-22-2012, 07:17 PM
Mirror Image's Avatar
it should be weled at the floor where the door opens and in the front below the door and at the bottom of the rocker and it will be weled to the bottom of the quarter it will also to the floor under the quarter
Old 08-23-2012, 06:55 AM
deadbodyman's Avatar
Wiki Edits: 11
Since thats a unibody car there will be an inner structure but the outer rocker will pop right off once the welds are drilled out...look where the weather striping slips on the lip theres at least three layers of steel pinch welded together you dont have to drill out all three layers, just the top one to remove the outer rocker.same with the bottom pinch welds...getting it seperated from the 1/4 bottom will be a little tricky if you want to save the rocker,why do you want to remove it?
Old 08-24-2012, 08:47 PM
I want to be sure there is no rust anywhere.
Old 08-24-2012, 10:01 PM
put up or shut up
Are you replacing the outer rocker cause of rust? Be sure to plan your welding attack before drilling out spot welds. You don't want to drill them out on the bad side and realize it when you're welding. Been there before...
Old 08-25-2012, 03:52 PM
Hopefully I can drill the spot welds out carefully and possibly reuse the rocker. It seems solid but I can see rust inbetween the seam at the bottom.
rocker panels zoomblack19 Body - Exterior 0 04-30-2010 02:29 PM
rocker panels ???? 68FB347 Body - Exterior 7 11-16-2009 08:31 PM
56 buick rocker panels zedsdead56 Body - Exterior 1 12-23-2008 09:09 AM
Side rocker panels hirax Body - Exterior 7 06-24-2007 03:21 PM
Rocker panels on 69 Camaro huff'scar Body - Exterior 2 09-30-2006 08:35 AM
