Firebird with T-350 speedo gear change question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2012, 09:38 PM
I changed from 241 to 308 rear end and changed speed about 15 mph faster than should be . Any idea what gear I should change to ? I have a firebird w/th350 !! Thanks
Old 06-08-2012, 01:08 AM
Wiki Edits: 85
If you are 15mph faster at 15mph, then double the gear teeth. If you are 15mph faster at 30mph, then multiply the gear teeth by 1.5. And so on.
Old 06-08-2012, 05:56 AM
It seems to be about 15 mph. at around 55 mph. I drive at 65 to 70 mph. to maintain a 55mph. according to driver that follows . Thanks for the feed back
Old 06-08-2012, 08:24 AM
RWENUTS's Avatar
Sounds like you're about 20% off. Here's a link to a speedo adaptor.
http://www.ebay.com/itm/NOS-AC-DELCO...41f1fe&vxp=mtr
Old 06-09-2012, 04:46 PM
rusthater89's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm
This will tell you.
t-350 speedo gear 383mc Transmission - Rearend 4 07-20-2009 09:39 PM
200r4 speedo gear change? Billz428 Transmission - Rearend 5 05-20-2009 02:22 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
TH 350 Speedo Drive Gear Mr Bob Transmission - Rearend 11 01-12-2007 05:37 AM
powerglide to 350 speedo change? briwill Transmission - Rearend 1 11-12-2002 02:31 PM
