Firebird th350 gone wrong - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2007, 11:05 AM
Hello all, here's my issue:
1968 Firebird w/350, had a 2 speed power glide, trying to up grade to th 350,
bought a used th 350, casting letter on top of trans is a large capital "D" (not sure what that means if anything) rebuilt trans, added shift kit new torque converter all went well till I tried to bolt up to my Pontiac 350 engine code YJ,
trans doesn't fit, only the bottom outside bolts and the alignment pins align. Flex plate and converter align! But that's it, Where did I go wrong?? I don't believe 2 bolts will hold this together! Is there a difference between Pontiac and Chevy bolt pattern?
thanks in advance
Shawn
Old 06-16-2007, 11:20 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Yes, one is called BOP pattern & then there's Chevy
Old 06-16-2007, 02:29 PM
Re: Th350 Gone wrong
The bolt pattern from the Pontiac and the Chevy TH350's are different and they are not interchangable.
The top of the bell housing on the TH350 for a Chevy is peaked.
The top of the bell housing on the TH350 for a pontiac/olds/buick and cadalliac are dipped between the two top bolt holes and only two bottom bolts line up between the two makes. They are NOT sufficient to hold.
There are "universal" bell housings but they're rare.
I KNOW thats good info for future use.
Old 06-16-2007, 03:50 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I used a JW Ultra Bell to bolt a Chevy transmission to my engine. They're SFI approved and not to hard to install. By the way, the two speed, that came in your bird, is not a powerglide. It's a Super Turbine 300. Not near a good as a glide.
Old 06-17-2007, 07:24 AM
The TH300 is a very good 2 speed unit, and is much stronger than a stock powerglide. For a 2 speed they were a very good unit for durability. There was a trans brake for them a few years ago. As to what their worth.......
Old 06-17-2007, 01:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks in advance
Shawn
As pointed out ... you need a BOP style bell housing for your engine.
BOP = Buick , Olds , Pontiac.....they fit many Cadillac engines too.
The guts of the chevy t-350 you will fit into the BOP case... There are some minor differences , but a simple thing to swap parts out for a fellow with some tranny knowledge.
post back if more questions come up
Problems modifying my 79 Firebird T/A Arabian Bandit General Rodding Tech 16 05-27-2005 07:20 AM
HELP!!! Differential Repair from Hell! If it can go wrong, it has! BCinDC Transmission - Rearend 2 03-13-2005 11:13 AM
M II Frontend, Whats wrong here Bluepen Suspension - Brakes - Steering 7 02-28-2004 07:48 AM
TH350 and what happened to 2 gear? Fryksten Transmission - Rearend 5 02-25-2004 08:46 AM
th350 rebuild b/w72 Transmission - Rearend 3 02-01-2003 06:53 AM
