Originally Posted by Mutt's37Buick
I'm installing a 94 Accord HVAC system in my 37 Buick.
I need 2 inch inner diam and 1 inch diam grommets for the AC & Heater lines that go through the firewall.
1) What are best firewall grommets for AC & Heater lines?
2) Can I use any common wire grommets or do I need parts made out of special material to handle the heat and cold?
3) Should I go with a large OEM style grommet with two holes or would two smaller grommets work?
Thanks
This stuff ain't cheap but it is so good.
Molded Grommet Strip, Rubber Grommets at cableorganizer.com
Bogie
