Firewall mount Pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 09:32 AM
I am looking for a firewall mount brake pedal for my 32 ford .it needs to just mount to the firewal and not the upper dash, this is for non power and needs to be a 6.1 ratio. has anyone seen something like this? all the brake sites i go to dont seem to have it. Is this something I am going to have to make? Thanks for any help
Old 02-11-2009, 09:42 AM
life is a temporary assignment
Try speedway..
Old 02-11-2009, 09:52 AM
firewall mount pedal
Tried them, they have to mount to upper dash and firewall.
Old 02-11-2009, 10:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I made mine from an S-10 brake mounting bracket and pedal and adapted a manual cylinder to it..I did beef the firewall a bit in the mounting area..used some 10 gauge steel for that..Looking around and being creative can be good..
Sam
Old 02-11-2009, 10:41 AM
For a little over 200 dollars ... you can buy a under the floor mount pedal setup from TCI ...
I have found that a firewall mount on a 32 Ford ... makes working on the engine difficult ... and it does not LOOK as good either IMHO.
Old 02-11-2009, 12:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
I made a brake pedal, firewall mount bracket and incorporated it all into a mount for a stub column. This is on a 33 pickup, very similar to a 32. You will need to reinforce your firewall, no matter which type pedal you use.
I made it with a 5:1 or 6:1 ratio, lowering the pedal down to the lower hole in the bracket and drilling a hole about 3/4" higher in the pedal makes it from a 5:1 into a 6:1, which worked out well with a manual master cylinder and disc brakes.
Later, mikey
BE different....ACT normal.
Old 02-11-2009, 12:41 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
would this work for you?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old 02-11-2009, 12:58 PM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
It looks like Kugel or ECI may have what you are looking for. Kugel has both the through-firewall mount and 90* and 180* under dash mounts for the M/C. It's hard to tell from the photos, but it appears that the ECI unit mounts between the dash and the firewall....
http://www.kugelkomponents.com/produ...akesystem.html
http://ecihotrodbrakes.com/hanging_p...ssemblies.html
Hope this helps,
Steve
Old 02-16-2009, 09:38 AM
Thanks for all the help
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 10 12-23-2013 10:47 PM
Staggered or straight mount starter? HotRodMan Engine 5 09-12-2006 09:30 PM
1969 Camaro gas pedal harry48 Interior 1 04-21-2005 08:17 AM
Lokar Gas Pedal Installation? fairlaniac390 General Rodding Tech 2 02-13-2005 09:52 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
