firewall pass through - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2006, 06:37 AM
Turbo Indian's Avatar
I'm looking for a small block that I can attach to the firewall for things like my aftermarket gauges. I'm wanting a block that can do about 6-8 wires. I need to keep it small & inconspicuos. I have searched here & Google but I don't know what it is actually called. can someone please point me in the right direction? I have looked at the Painless catalog & did not find what I'm looking for, unless I over looked it. I do not want to just use a hole & fish the wires through it.
Old 02-26-2006, 11:49 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Amphenol makes just what you want.
You will need something waterproof with #18 wire capability (for gauges) . I prefer solder type but crimp type are available. A special tool will be required for crimp type.
Google--key words : military circular amphenol connector
Chose: www.newarkinone.com
It's easier to find things in their catalog thru Google.
Also there are many surplus sites.
Happy hunting.
vicrod
Old 02-26-2006, 01:23 PM
it's just terminology that gottcha', try: "bulkhead electrical pass thru" on google
attached pic is from Pave Technology (pass thru's and connects), is the far right what your thinkin?
if yes, think seriously about making your own and round....much easier to cut a round hole and trim a home made rubber plug than cut an exact rectangle hole in the firewall
Name:	bulk head connects.jpg
Old 02-26-2006, 03:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I have used the Round Amphenol Connectors like Vicrod described..and they are SWEET!
Easy to install, (just use a round metal holesaw, and four screw holes) You can "Pot" them by applying anything from electricians putty to light hydro-seal, and if you put the face side on the inside of the firewall, It will be waterproof, and pretty much fume proof.
Plus if you get the inserter / Extractor, pin movements and additions are a breeze..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-26-2006, 04:07 PM
clarification/correction due to brain rot:
much easier to trim a round hole to fit a plug made from a body access plug or similar that can also be trimmed alittle for a really tight fit....
anyway, I'm with Vicrod and Doc, would use a "bulk head connector" thru the firewall... not a "pass thru connector"....unless it is something very ohms sensitive
Old 09-07-2006, 05:19 PM
update!!!! Caspers electronics now make somthing for this application!!! check it out I think it will help out a lot of folks.
https://www.casperselectronics.com/M...Category_Code=
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
How do you refinish a firewall? NoClone Body - Exterior 7 08-18-2006 03:22 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
engine to firewall clearance fezz-man Engine 2 05-10-2005 08:49 AM
47-53 Chevy Truck firewall bg Body - Exterior 4 12-31-2004 09:42 PM
