Firing no.1 Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2012, 01:08 AM
Well i installed a camshaft, lifters, timing chain, etc, so I set the static timing on my Chevy 350 and it sounds like it wants to start cranks and crank and cranks, but nothing sounds good too, but doesn't start.. It's set to 10 BTDC then rotor to cylinder no.1 and nothing..
What do I do now, I heard someone say that my timing could be retarded ...MEANING?
Old 08-15-2012, 02:03 AM
The mobile view is crap
180 off on distributor?
Old 08-15-2012, 05:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Retarded would mean the distributor needs to be turned CCW more than it now is. Often when the distributor is turned too far advanced the engine will act like the battery is low or the starter dragging- it'll turn over slowly.
Take a look here. Also at the bottom of that page are several links to more info like how to make a timing tape and the differences in the SBC timing tabs and dampers through the years that can get mixed up- and results in a false timing reading.
Also be sure that the plug wires for #5 and #7 aren't mixed up. They are next to each other on the distributor cap AND the plugs are next to each other at the driver side cylinder head.
Old 08-15-2012, 05:58 AM
BOBCRMAN@aol.com's Avatar
Here is a worse case. Happened to an older customer of mine just this week.
Changed timing set (a three position unit). Installed a roller cam and retro-fit lifters SBC.
He called me to check the timing for him. He had the upper gear dot lined up with keyway. I told him no. Place timing marks dot to dot..
Calls me Monday and says engine won't fire and is pushing pressure out of carb.. Long story short. I went over to see and he had lined up the cam dot with the retard mark on lower gear. Bent all the intake valves and pulled all the intake rocker studs.. NOT a good day for him..
Yours is probably ign 180 out, as mentioned above..
Old 08-15-2012, 08:34 AM
Um......wow! All this was done with just the starter rolling the engine?
Old 08-15-2012, 08:38 AM
You're exactly right the The motor does sound like the battery is low, and a little draggy, it does turn over slow
I don't have 5 & 7 mixed up because theirs no miss or ruff ness just slow turn over
Old 08-15-2012, 11:17 AM
1971BB427's Avatar
Have you tried moving the distributor a few degrees either way while someone is cranking the engine to see if it catches. Don't worry too much about having the timing set perfectly until you get it running.
As a last resort you can pull the distributor cap and #1 spark plug, then crank the engine with your finger over #1 plug hole. When it pops off stop, then check the position of the rotor to see if it's pointed near #1 on the cap. If not then you can adjust as needed to get it in the ballpark.
Old 08-15-2012, 05:02 PM
What position did you align the timing marks on the gears? When they face each other (crank at 12 and cam at 6) the camshaft is timed to fire number 6 not number 1. From the installtion instruction that has the gears aligned toward each other; the crank needs to be turned one revolution clockwise, looking from the front, to bring both marks to the 12 o'clock position which is then set to fire number 1. If you didn't do this last rotation before dropping the distributor in place, then if you set it up the distributor to fire number 1 it is 180 degrees out as when the pip marks face each other it is ready to fire number 6.
The quick fix is to align the distributor to firing number 6, remove the hold down, raise the distributor, turn the rotor shaft so it's pointed at number 6 and drop the distributor back into place and fasten it down.
This is a common problem that bites everybody at least once.
Bogie
Old 08-16-2012, 12:37 AM
Well I turned it on after like 3 months of rebuilding and turning the motor around, a lot of research and forum hopping thanks for the help
Old 08-16-2012, 11:20 AM
1971BB427's Avatar
You turned it on? Are you saying youu got it running? If so, what did it take to get it to fire up?
Old 08-16-2012, 05:10 PM
Yeah I got the car running, I placed the harmonic balancer mark at 10 BTDC and put the rotor facing the no.1 cylinder like I been doing, but this time with one arm on the
Key to turn it, and stretching my other hand on the dizzy, ( I'm 6'3 my arms are long) and turned the key and slowly retarded the time till it caught up and vrooom it turned on
Old 08-16-2012, 05:42 PM
1971BB427's Avatar
That's the way I do them! Glad it worked!
My crank open windshield on the gasser makes tuning and cranking the engine even easier!
firing order for a 350 chevy engine taylormade7969 Engine 3 09-21-2010 04:47 PM
firing order 350 chevy Dozer6968 Engine 1 05-04-2010 08:25 PM
marine 350 chevy firing order goof ball Engine 6 12-08-2006 06:39 PM
chevy 350 firing order badazz elco Electrical 5 07-13-2004 07:01 AM
firing order for 350 chevy cleaner21 Engine 6 07-07-2003 02:38 PM
