firing order 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 07:55 PM
Dozer6968's Avatar
Hi guys I have a 95 chevy 4x4 350 I bought last fall. Good truck and all but I thought it was lacking power and sounded like it would miss every now and again. The first thing I did was change the plugs which seemed to have helped but still not what it should be. I went and bought plug wires today and went to change them. I checked the firing order on the manifold and looked at the distributer and noticed it wasnt in the order on the manifold which is18436572. My truck is running with a firing order of 12758346 slugish but not back firing or anything. What I would like to know is if it is out 180 degrees or more.
Old 05-04-2010, 08:25 PM
ericnova72's Avatar
More for Less Racer
The correct firing order is 18436572, odd numbers 1,3,5,7 are on the drivers side, even numbers 2,4,6,8 are passenger side, from front to back. Clockwise around the cap looking down from aboveThe way you have it wired now doesn't match any of the other two ultra-performance firing order swap cams either that racers use, so that idea is out. I'm amazed it runs very well at all the way it is now
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 10:11 PM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 03:10 PM
350 buick in chevy truck? jrm123180 Engine 7 04-04-2004 12:03 AM
350 Dist. Firing Order bigjeepinyj Engine 1 10-10-2002 01:38 PM
