Firing Order - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2005, 05:17 AM
Firing Order
I accidently goofed up the plug wires on my GM stock 350. Does anyone know a website which will show me the firing order for both the block as well as the distributor. I can not locate them on the car either on the block, intake or distributor cap itself. I am new to this mechanic stuff and this is my first learning curve. Please help. Thanks
Old 06-30-2005, 06:21 AM
Technical Support Barry Grant
Firing order
SBC Firing order 1-8-4-3-6-5-7-2
Drivers side of engine from front (radiator) to rear (firewall) 1-3-5-7
Passenger side of engine from front (radiator) to rear (firewall) 2-4-6-8
Remove your #1 spark plug, and rotate the engine over to the compression stroke. Your finger will get pushed out of the hole. Now look at your balancer, it should line up with the timing marks. Now remove the distributor cap. The rotor should be facing towards #1 cylinder. That is where you start with your #1 plug wire. Now just go around the cap clockwise with the rest of the firing order 1-8-4-3-6-5-7-2
Old 06-30-2005, 06:26 AM
Thanks
Thanks for the information Tech@BG. I reall appreciate it. Car show this weekend and I thought I was taking the bus! Thanks again
firing order FordTrouble Engine 8 11-27-2004 11:22 PM
Firing order wont work delory Electrical 15 05-07-2004 11:22 AM
Carburating a 5.0 HO. Firing order question FalconDaman Engine 7 12-07-2003 03:00 PM
Firing order on a slant six?? Rodder318 Engine 3 02-23-2003 07:17 PM
84 305 firing order, please help nitro junkie Engine 7 01-08-2003 12:38 PM
