Firing order and Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 03:45 PM
colincamaro's Avatar
Wish I grew up in the 60's
Hey i need some help, i have a 1971 el camino 350ci engine. does anyone have a diagram of the firing order (i don't have the original intake manifold with the order on it)? I also have a standard hei distributor from that year, does anyone have a diagram for the firing order of that thing as well? Last question, if you are given the firing order as 34768125 (not a real order) how do you tell which number goes with which plug hole? Any help is appreciated i am trying to get this car moving again. thanks again,
colin.
Old 12-27-2006, 04:00 PM
http://boxwrench.net/specs/chevy_sb.htm
The firing order is 1-8-4-3-6-5-7-2 is followed in a clockwise manner around the distributor. It really makes no difference which terminal is #1, as long as it is followed by #8, then #7, etc.
Start by setting the #1 cylinder at TDC in the firing position, then establish which terminal is going to be #1 by installing the distributor. If you have a favorite position ( many prefer the terminal closest to the #1 cylinder ) assure that the rotor is pointing that way when you install the distributor. You may have to adjust the position of the oil drive rod to get the proper engagement at your desired posirion. Assure that the vacuum advance canister isn't going to obstruct the rotation when you need to rotate the body to get your timing correct. After you've established the #1 position, follow the firing order in placing the rest of the wires clockwise around the cap.
Old 12-27-2006, 04:09 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
As the cars came from the factory
#1 on the distributor should be to the front of the motor on the passenger side.
pointing toward the #4 & #6 intake runners.
Bryan
Old 12-27-2006, 05:27 PM
Mustangsaly's Avatar
this what you want ?
Mustangsaly
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
Screwed away the firing order 1968 Firebird 400...HELP stevo68 Engine 6 06-09-2011 08:05 PM
Distributor Installation & Firing Order leejoy Engine 9 01-05-2006 04:18 AM
Firing Order 67 Hugger Engine 2 06-30-2005 07:26 AM
chevy 350 firing order badazz elco Electrical 5 07-13-2004 07:01 AM
Firing order and #1 Distributor location Kevin45 Engine 0 09-17-2003 05:42 AM
