firing order ect. for Ford 330 truck motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2007, 10:37 PM
mike 96 ws6's Avatar
old dog learning new tricks
Also I need to know cylinder number locations and distributor direction of rotation?
TIA!!!
Old 03-25-2007, 11:14 PM
TIA!!!
Bump:
OK, I can find out the direction of rotation but I still need a firing order.
Anyone?
Old 03-26-2007, 02:03 AM
aka Duke of URL
The FT firing order will be the same as the FE;
1-5-4-2-6-3-7-8
Old 04-24-2007, 04:52 PM
1-5-4-2-6-3-7-8
Thanks KULTULZ!!!
After searching several sites I finally got back around to this project after obtaining 3 different firing orders for this truck.
1 = 13726548
2 = 15786342
3 = 15426378
Your information proved to be correct.
For the sake of anyone elses future search reference, I also found the direction of rotation of the distributor to be counterclockwise.
My particular truck required position of the #1 plug wire to be connected at 9 O'clock position on the cap, {viewed from the front of the vehicle}, although the #1 mark on the cap was in a different location. Of course, this is only because someone has previously removed, then installed, the distributor shaft in this position in order to enable proper engagement of the drive, then oriented the wires on the cap to coincide with the proper ignition timing index area.
I found #1 TDC {end of compression stoke - at fire position} position of the distributor driveshaft by removing the #1 spark plug, then rotating the motor in the correct operating direction until compression was observed on that cylinder, then simply used a coathanger to watch the position of that piston until at TDC.
Maybe this info will be of future help to someone like me!!!
Thanks again KULTULZ.
Chevy 4 & 7 Swap Firing Order SnakePliscan Engine 8 02-04-2005 06:22 AM
Firing order wont work delory Electrical 15 05-07-2004 11:22 AM
My 72 360 FE Truck motor RideDannyRide Engine 31 09-22-2003 03:45 PM
Firing order on a slant six?? Rodder318 Engine 3 02-23-2003 07:17 PM
84 305 firing order, please help nitro junkie Engine 7 01-08-2003 12:38 PM
