firing pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 09:57 AM
firing pattern
I need a diagram for the firing order of an older model GM engine sequince of 165432
Old 03-18-2012, 10:10 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If this is a 3800 V6 in a transverse application, the cylinders on the radiator side are numbered 1-3-5 front to rear while the cylinders closest to the firewall are numbered 2-4-6 front to rear.
You already have the firing order, 1-6-5-4-3-2.
standard bolt pattern on duel pattern heads nskeeter99 Engine 1 02-15-2009 01:41 PM
Dual pattern Cam vs. Single pattern Cam Malibu73 Engine 7 02-13-2006 10:33 PM
Single Pattern VS Dual Pattern Lthompson Engine 20 02-20-2005 06:19 AM
dual pattern vs singel pattern martien bierlee Engine 3 01-19-2005 04:34 PM
Firing r350xx Introduce Yourself 1 08-07-2004 09:42 PM
