Firming up TCC lock up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 07:51 PM
blacklabzeke's Avatar
Is there any way to firm up the TCC lockup? I have heard that removing the ball in the end of the turbine shaft will do this. Will this have any ill effects on the converter or other parts? I am running a stock 12" converter in a 4WD with a 1988 700R4.
Old 03-28-2007, 07:44 PM
Removing the orificed checkball inthe input shaft will make lockup more firm at the expense of the damper springs and TCC apply plate.
This is generally NOT recommended.
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 06:44 PM
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 03:13 PM
Problem installing line lock airman_turtle Suspension - Brakes - Steering 3 07-04-2005 11:35 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
