First Attempt at Door Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 01:55 PM
mustang_Tomsilver's Avatar
Classic Mustang Maniac
Hi all,
I this is my first attempt a making fiberglass anything. I figured to jump in and go for it.
Anyway I have made a card board template of the driver side door panel.
As you can see in the pics below part of the panel is to be raised(outer part of the panel) but I want the overall thickness (excluding the arm rest) to be only about 1/4". The standard door panel for a 66 Mustang is around 1/4 basically cardboard wraped in vinyl.
I guess my question is does the panel have to be backed with plywood like lauan then covered in fleece?
Or can I have a fiberglass(fleece and resin) back and build on top of it with more fleece to make the raised portion.
Also does anyone recommend strengthening the panel with mat?
Any other tip are appreciated as well.
Thanks for any answers,
mustang_Tom
ID:	8443   Click image for larger version
Old 12-17-2005, 04:12 PM
Tom, I don't have any advice since I am an amateur at glass work myself. But I am wondering are you talking about just the door insert panel or doing the whole door? The reason I ask is I am thinking about making a glass panel that would cover the entire door. The plan is to cover the door with release agent of some type and then do a lay-up with thin cotton cloth and resin from the window felt all the way to the weather strip and then have this shell upholstered to make a removable panel. I plan to use a pony type panel insert in this removable panel. I was hoping to find someone who has done this before.
Old 12-17-2005, 05:27 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
i would think you would want to use the mat it will strengthen the door panel and keep it all together, you can use fiberglass that has the "hairs" or "strands" already in like "gorilla Hair" and that stuff is tough as nails. the fiber glass final product is stronger when it has the "strands" or mat as part of it.
Old 12-17-2005, 07:17 PM
Last journal entry: My 67 Nova Build
check this site out - these are the real pro's at doing fiberglass interior stuff on cars. they have a section talking about how they did the door panels as well as everything else in the car - killer work. If i were you i would use some 1/8th inch medite from home depot and then glass on top of that - this way you could put door clips into the panel like a normal panel would have (hidden of course). also if you want to use say a 3oz glass mat with resin you could first lay use polyester fabric from any fabric store stretched and stapled down over your raised area's - that is how guys are getting the flowing curves etc. granted fleece eliminates the need for the glass mat but man it has got to be heavier than **** once soaked in resin, plus stretched polyester will giver smoother crisper curves , lines etc. - also be aware that a coat of marglass is important to prevent warpage before taking the panel out of the car after glassing (for finishing etc) - i learned this the hard way with a headliner +200 bucks wasted on materials. hope this helps
http://iweb.alpine-usa.com:7777/html...003_civic.html
Old 12-18-2005, 07:47 AM
Thanks for the info
And yes I am only doing the insert for the door not an entire panel, so there would be no hidden clips to secure the panel to the door.
I want it to look some what stock (in a sense).
Since the panel has 9 screws that held it to the panel I still want to use this
method of securing the panel to the door.
However I want to use polished stainless steel (or chrome )button head allen bolts.
I guess my next step is to get some plywood as a base and get to work.
Thanks again
Do not attempt this at home or anywhere else bracketeer Engine 31 12-12-2005 03:19 PM
First attempt at Photochopping Dusty82 Hot Rod Art 8 10-05-2005 07:40 PM
First attempt at a hot rod, hopefully 4Birdman Introduce Yourself 4 08-18-2004 07:19 AM
My first real attempt at body work. What do you think? Ghetto Jet Body - Exterior 9 06-23-2004 04:40 PM
1st attempt at painting!! Pony Body - Exterior 4 05-26-2004 12:38 AM
