Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First BBC, urgent help with timing!
Old 04-10-2010, 04:55 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
Welcome to HotRodders.com Glad to have you with us.
Chevy's Dist. rotate clockwise, so buy turning the dist CC. you were advancing the timing further.
I have a buddy that can't get this right either, so now he takes the valve cover off & watches for both valves to be closed, then lines up the pointer at 0*
It's not necessary to change the dist location, you can just change the location of the wires, after you have #1 at TDC wherever the rotor is pointing, make that tower the #1 plug wires new home.
Plug gaps, fool around a little with the gaps, you may find a closer setting may work better for you
You can change seals while the heads are still on
Rich
http://boxwrench.net/specs/chevy_bb.htm
