Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First BBC, urgent help with timing!
Old 04-13-2010, 05:55 AM
redsdad redsdad is offline
Will I ever get it done?
Last journal entry: Hood
Originally Posted by richard stewart 3rd
Hi,
just unbolt the rocker & replace it
Not so fast. I put a very mild cam in a 396. Even so, the rocker slots bottomed out on the studs, causing similar damage to what you see here. Closely examine the valve end of the slots and the studs to see if yours are bottoming out. Then buy a set of rollers.
