First BBC, urgent help with timing! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-14-2010, 03:49 PM
How straight do the push rods need to be? I rolled them over glass, and one will need replaced for sure. The other two roll pretty smoothly, but if I get eye-level with the glass, I can see a slight(hair thick) bend to them. Should I replace them?
  #17 (permalink)
Old 04-14-2010, 08:12 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It would be worth some peace of mind knowing you have new straight ones. They are not that much $$$ and new ones will save you from having to do it again. If possible, go with the 3/8" diameter chrome moly pushrods.
  #18 (permalink)
Old 08-05-2010, 08:33 PM
wow man that looks pretty bad would definately affect compression. and no the valves will not fall into the engine if u take out the rockers and push rods cause they are held in by retainers that are held into a groove machined into the top of the stem held by the pressure of the spring. youd need to take the heads off in order to get the valves out. so dont worry about loosing the vaves into to engine. and the best way ive found to get the distributor lined up in the factory position for #1 is to get the engine to compression. and i always line up the mark on the balancer with the 0 mark on the scale. that is where the piston is all the way up in the cylinder. then i pull the distributor and line it up with the number one tower on the cap then turn it counterclockwise back just a little before #1 then drop it in the hole and twist it clockwise a little till the gear lines up then it will be lined with the correct tower. then i bump the starter to get the oil punp shaft lined up till the distributor falls down all the way then ur golden. after all that i normally get the engine back to tdc on #1 to double check the alignment. its never failed me. so give it a try. sorry about the wordiness of this but it takes alot to explain
  #19 (permalink)
Old 08-05-2010, 08:38 PM
but like every one else said it dont matter where the rotor ends up at #1 cause all u need to do is just change the locations of the wires. i just prefer to have #1 in the factory location it makes it easier to put the wires on
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 06:47 PM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 04:49 AM
Timing / advance eatonde Engine 1 10-08-2008 05:48 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 05:26 PM
