Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First build disaster!
Old 08-06-2012, 06:19 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by Chevyfan16 View Post
I used new ARP bolts with permatex sealer and oil under the heads. I used those head gaskets because it gave me a quench of .035 which is pretty close to perfect. I don't know of any other head gaskets that would give me proper quench.
The steel shims gaskets usually have a minimum rma surface finish. I was always told to use copper head gasket spray with them. Hopefully you didn't hurry anything and can replace them and be on your way.
