Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First build disaster!
Old 08-06-2012, 11:51 PM
4inthefloor 4inthefloor is offline
you running cast or alum heads? if there cast your probally fine,,, if u have alum heads on a cast block you need to put a straight edge across the head and see if everything looks kosher. cast and alum disapate heat at different rates and it makes it faily easy to warp alum heads on a cast block. also, make sure you have antifreeze in the motor even cranking for break in becasue antifreeze brings down the boiling point of your coolant
