Water in cylinder has nothing to do with valve seals...What does the head gasket and intake gasket look like?
Ontario Rodders |
Intake gasket looks good, head gasket is hard to tell because it's a steel shim felpro. However during assembly I forgot something and had to take the head off after I had torqued it. After it was all said and done I second guessed myself because the head gasket had been crushed already.
Bolts need to be lubricated and in the case of the Chevy sealed. The OEM torque values are for a motor oil lubricated threads and bottom of the head. The Chevy needs a sealant as well which is a place where plumber's Teflon pipe thread sealant satisfies all these requirements. Bogie |
I used new ARP bolts with permatex sealer and oil under the heads. I used those head gaskets because it gave me a quench of .035 which is pretty close to perfect. I don't know of any other head gaskets that would give me proper quench.
The steel shims gaskets usually have a minimum rma surface finish. I was always told to use copper head gasket spray with them. Hopefully you didn't hurry anything and can replace them and be on your way.
Did you refill the radiator after the thermostat opened, and burp it? You could have a air lock.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
i dont know what you have this 355 in but if its a custom set up and the rad cap isnt the highest point of the cooling system you'll get air trapped in the intake and youll have to but a bleed valve in the thermostat housing and force you coolant in to the rad once you have it topped off. i use a old 2 lieter bottle
It started over flowing out the radiator so I put the cap on....it sucked a lot out of the over flow bottle. I really thought it was an air pocket like you said, but I didn't know how to figure out if it was an air pocket or not.
put a secound temp sensor in the intake or thermostat houseing,, if your temps vary you probally have a air pocket.....you need to leave the cap off untill its up to operateing temp and the thermostat opens... it will just about empty the rad when it opens
you running cast or alum heads? if there cast your probally fine,,, if u have alum heads on a cast block you need to put a straight edge across the head and see if everything looks kosher. cast and alum disapate heat at different rates and it makes it faily easy to warp alum heads on a cast block. also, make sure you have antifreeze in the motor even cranking for break in becasue antifreeze brings down the boiling point of your coolant
Cast heads!! And I'll be sure to put coolant in and not just water....do you think a 195 thermostat is okay? Thank you very much!
| The Following User Says Thank You to Chevyfan16 For This Useful Post: | ||
jexrod (08-07-2012) | ||
| Bp Oil Rig Disaster | OLNOLAN | Off-Topic | 4 | 06-22-2010 10:48 AM |
| Plastic bumper disaster | Bartman | Body - Exterior | 15 | 10-29-2009 05:29 AM |
| recipe for disaster...... | bigblockking21 | Hotrodders' Lounge | 6 | 02-27-2008 06:40 PM |
| 400 disaster--HELP! | 75_ranchero_429TJ | Engine | 24 | 10-03-2007 04:38 PM |
| Dyno disaster | lust4speed | Transmission - Rearend | 5 | 03-01-2005 06:55 PM |
