First carb rebuild Please help with Vac Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 11:07 AM
highwaystar's Avatar
Last journal entry: Some finished pictures
Hello Everyone,
My 66 Satellite was starting to run poorly so I though I would rebuild the 2bbl Stromberg WW. The rebuild seemed straight forward but I couldn't get it to run right (ruff idle will barley drive). After playing with the only two adjustments (accelerator pump and float level) I discovered I have massive vacuum leaks. There is only one hose coming off the carb for advance and that was replaced. If I take starting fluid and just lightly spray on the body of the carb the rpm's surge and if I close the choke it runs better.
I didn't use and gasket sealers during assembly because it doesn't seem like a good idea but how do I get rid of these leaks. It didn't run THIS bad before I touched it.
Thanks for any tips.
Old 08-20-2008, 01:44 PM
bet on black's Avatar
hotrodder 4 life
take it apart and clean any and all gasket material off the flanges under the carb, and wherever the carb comes apart, and put on new gaskets.
Old 08-20-2008, 02:50 PM
"always check simple first"
retorque the carb mount bolts to the correct ft/lbs...
a first motor heat cycle hot to cold can cause a new base gasket leak...
25 Year-old Carb, rebuild or trash? Arcuden Engine 6 07-31-2005 08:42 PM
Holley Carb Help? (ID + Rebuild Kit) xelysianplainsx Engine 6 12-28-2004 05:41 PM
Carb rebuild Jms8800 Engine 6 06-13-2004 04:55 PM
holly 600 carb rebuild earl pilloud Engine 1 06-10-2004 09:39 PM
vac secondary carb or double pump??? maddmaxx Engine 10 11-01-2003 01:53 PM
