First coat of primer over a combo of bare steel and body filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2010, 08:20 PM
What can the voices of experience recommend as the best primer to use when body filler is applied directly to metal leaving a combination of bare steel and body filler as the substrate? This will be the first coat of primer to followed by guide coats etc.
Old 03-23-2010, 08:29 PM
302 Z28's Avatar
Epoxy primer then a good quality 2K primer/surfacer. I prefer SPI epoxy.
Vince
Old 03-24-2010, 12:56 AM
Countilaw's Avatar
Cox Custom Cars
What 302 said, except I use Kirker Epoxy primer.
Just had to add that!!!!
Frank Cox
Cox Custom Cars
Old 03-24-2010, 08:41 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Hey Count,
do you have any pics of the kirker epoxy you used? I'm hopefully going to be spraying their black epoxy today...my plan is to mix it 1:1 with no reducer over bare metal....
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Priming bare steel 4drgl Body - Exterior 4 09-03-2009 06:38 PM
Nason 421-17 primer over body filler? cboy Body - Exterior 3 12-17-2008 05:37 PM
Non-shrinking body filler for Corvette alittle1 Body - Exterior 3 12-20-2003 10:42 PM
