First engine build. 383? 355? Want 350-400hp. What do you do? - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
  #106 (permalink)
Old 05-10-2014, 02:27 AM
BigEd36's Avatar
Stingroo, the Speedpro pistons have a 1.548" "rebuilder" compression height instead of the standard 1.560 compression height for a 350 piston. To keep your quench height at .040" you'll have to have your block decked, and probably have to run a shim head gasket. The factory spec has pistons nominally .025" below the deck surface at top dead center, add the .012" that the shorter pistons have gives you .037" "in the hole". The thinnest head gasket I know of is .015", which would give you a quench height of .052", which isn't very good. With flat top pistons and your 64cc Vortec heads your static compression ratio will be around 10:1 - 10.2:1, which is pretty high for iron heads on pump gasoline. For detonation resistance you'll want to keep the quench tight.
  #107 (permalink)
Old 05-10-2014, 10:04 AM
Fstarocka's Avatar
Combo 53 uses rebuilt #993 GM heads with 2.02/1.60 in. valves. The camshaft is a healthy grind, with 234° of duration @ 0.050 in. of lift. This 355 cu. in. engine produces 421 HP and 438 ft-lbs of torque.
Displacement: 355 cu. in.
Carburetor: 750 Holley vacuum secondary
Heads: GM #993 castings, ported, with 2.02/1.60 in. valves and a 3-angle valve job
Intake: Edelbrock Victor Jr. and a 2 in. open-plenum spacer
Camshaft: Cam Dynamics 290, with 290° of duration, 234° of duration @ 0.050 in. lift, and 0.494 in. of lift
Headers: 1 7/8 in.
Pistons: Speed-Pro forged flat tops
Rods: stock
Crank: cast
Comp. Ratio: 9.0:1 to 10.0:1
MAX HP: 421 @ 5300
MAX Torque: 438 @ 4700
Theres something to look at - I havent compared all your parts, but have a look at the NA parts link i sent, and select the hyperteutic pistons, and look at some of those cams there - the elgin grinds are old school but Ive heard of many ppl making serious power with them. The Comp Thumpr #12-600-4 looks like u might like it, the 107 lsa will give a serious romp-romp idle, but cost a little bit of economy..
I would spend MORE money of good machine work, decking the block AFTER you have selected pistons, etc and look at this kit as an example. NA might have a smaller package as well, not sure - but buying the kit does save u some $$.
That intake can be had new for $134 fromm their site - with warranty. Its chinese knock off stuff, never tried / can comment but I have heard some horror stories about uneven flow, holes not lining up / cheap alloy uses resulting in warping etc.. might consider an edelbrock. I found a 2116 for $100 2 week ago.. anyway can always replace that later. Just thought id mention it..
You could aways look for a used HEI - I always believe in oem quality -
also bear in mind peak hp / torque fall within a rpm range, and u have to ask your self how much time will u realistically spend there? focus your power on where YOU will be driving the most, not peak numbers.
You might drop 50 off the numbers, but will pull away quicker
just my 2 cents - i dont want to throw a spanner in the works - but it took me about 2 years of slow research to gather ALOT of info, and still made some minor mistakes
  #108 (permalink)
Old 05-10-2014, 10:25 AM
No no, it's totally appreciated. I had no idea that Northern Auto even existed. I just kind of assumed Summit and the like was 'the place' to go for this type of thing.
If anything, you're saving me cash and helping me figure it out faster.
  #109 (permalink)
Old 05-10-2014, 10:27 AM
Fstarocka's Avatar
to quote techinspector1:
I have a DynoSim pull on file, 350 bored 0.030", these pistons
http://www.summitracing.com/parts/SUM-17350-30/
garden variety GM 883 heads, Edelbrock Performer RPM intake, 600 cfm carb, 1 5/8" long tube headers and this cam
http://www.compcams.com/Cam_Specs/Ca...x?csid=85&sb=0
Cut the block decks to 9.012" block deck height and use GM 10105117 head gaskets. Makes 380 hp @5000 rpm's and 430 ft/lbs of torque at 4000. Nice, cheap little street motor that will run on pump gas.
  #110 (permalink)
Old 05-10-2014, 10:34 AM
So here's the kit I bought from them....
I went with a new crank and balancing - figuring it's only a few more bucks, but it should pay off in the end, right?
It brings my total cost up to $1821, but that should cut machine shop costs (no polishing or balancing of crank...) so it's probably a wash. That's an awesome site!
Even found a 5% off coupon code, which basically makes shipping free. Awesome.
Here's what I picked:
  #111 (permalink)
Old 05-10-2014, 10:35 AM
Well damn. That's pretty much spot on for what I want. LOL And I have better heads, so... I should be good with my goals. Sweet.
  #112 (permalink)
Old 05-10-2014, 01:28 PM
Fstarocka's Avatar
man looks like youve made a gr8 purchase there. those scat cranks are gr8, overkill on the rods haha, stockers will take 400 any time and day.. ditch the high vol oil pump, can suck a stock oil pan dry, only for use in race applications with a deep pan. What cam did u get? there were some gr8 cam options on that list for you..
glad to have been a help so far. there are very experienced ppl here - you should have a stout motor with that bottom end!
Once you have the pistons check with some ppl here (perhaps a new thread) about deck height with your setup and have the block decked (if necessary) - this will allow higher compression and better power / delivery (quench is your friend).. but thats next steps -
  #113 (permalink)
Old 05-10-2014, 01:44 PM
Last wiki edit: Stroker 351 W Ford Motor=Building
rebuilding =383
For the $$ you have ?= id only do a SCAT forged 383 setup-can be had for under 900 bux -new & forged rotating assembly!! Bore =.030 over & find a set of chev fulie hrads= here in my area redone & ready for install-350-400 bux.bore & machine /hone & piston fits about 200 bux here- so u have now 1500 in a new assm-add gasket sets & intake & carb=?? 2 grand & all new & wonderful!! some will say thats way too cheap yet i have 2 here ive done same ways -i know !
  #114 (permalink)
Old 05-10-2014, 01:52 PM
Fstarocka's Avatar
true that, but a 383 for a 1st timers1st build might be a bit complicating given all the varying geometry of a 383, rod lengths, etc - gr8 suggestion as well for the $$
  #115 (permalink)
Old 05-10-2014, 03:11 PM
BigEd36's Avatar
You'll be happy with the service from Northern Autoparts too. When I've ordered from them it's always either shipped the same day I ordered it or the next day.
  #116 (permalink)
Old 05-10-2014, 03:53 PM
Haven't ordered yet! I just clicked a set of rods that were cheapest because it says you have to order rods for them to balance the assembly. I figure, that'll save money at the machine shop, too.
Just adding to cart. I've got like ~500 saved toward this all (after buying those heads, after all...). It's just going to my savings a hundred a week, plus income from my side job.
It's gonna have to be sooner than later, though. Just changed the oil on my wagon and found some shavings in it. Joy!
  #117 (permalink)
Old 05-15-2014, 11:03 AM
Cars, Trucks, Boats
. Those SpeedPro 345 pistons Silver Surfer suggested and on the Northern sheet are the same ones we discarded earlier because there were complaints on them not actually having the compression height spec'd... like BigEd36 also said above... and because the guy was getting damaged ones that others had already pry'd back off their rods and sent back when they discovered the compression height was wrong... that's why Eric and I suggested the KB claimer pistons with higher compression height than all others... they also eliminated the cost/need/hassle of decking the block to get proper engine quench...
. Don't know if the Summit pistons someone suggested live up to their C.H. spec.s or not, although lower than the KB's even if they do... but the price is tempting...
. The cam in Fstarocka's "Combo 53" (apparently from Ryan's Car Pages) above has a 234/234 cam... too big for your heavy car... I'd stick with the smallest Thumpr cam as very biggest to consider... (Like to know where he found Ryan's site mirror'd at, haven't been able to find them lately, they show a combo with 350", vortec heads, mild 214/224 generic cam at 380HP) ... If can live without a Thumpr cam, a Melling or Summit 214/224 cam would serve you very well (that size cam available under about 20 different brand names, including flat or roller ones from GM)...
. As long as still looking at parts sources, also check out:
ENGINEKITS.COM® - OE Stock and High Performance Engine Parts 661-861-0167
JEGS Performance Auto Parts - Holley - Billet Specialties - Edelbrock - MSD - Moroso - Mr Gasket - Free Shipping on All Orders @ JEGS (similar to Summit, shipping may be more)
. Use old crank and rods, keep new pistons at same weight as old ones, and you won't need to re-balance at this performance level...
. Will a taller distributor fit in there? (In the car?)
. SCAT cast cranks made in China, forged ones made in USA...
  #118 (permalink)
Old 05-16-2014, 04:25 PM
Fstarocka's Avatar
I found JUST that combo posted, but yes I do have a copy of ryans combos here, not sure how to share it without it being lost..
attached a zip and inside is the xls file, this shd be a sticky
  #119 (permalink)
Old 05-16-2014, 04:31 PM
I'm about to get off work. I'll make it shareable as soon as I get home and open the zip.
His numbers sound like... exactly what I want.
Not what my 700R4 wants, but what I want. LOL
  #120 (permalink)
Old 05-16-2014, 07:09 PM
BigEd36's Avatar
Here's the link to Ryan's combos on the Internet Archive Wayback Machine website from July 28, 2013. https://web.archive.org/web/20130728...m/combos1.html
my first real full engine build(350/383) levi1030 Engine 4 05-06-2014 02:35 PM
wanting to build a 350 close to 400hp for under $2000 Danny1986 Hotrodding Basics 16 02-20-2011 08:29 PM
wanting to build 355 or 383 need suggestions WHITExTRASH Hotrodding Basics 11 12-22-2010 07:18 PM
AMC ENGINE BUILD UP - need supercharged 400hp+... erkii Engine 5 08-25-2010 08:13 PM
build me a 400hp 350 F3RR3T Engine 15 09-06-2007 06:26 PM
