First engine build, BUDGET 351w. Need machine shop help....What to ask?
So, after losing oil pressure in our Bronco with a 351w, last week, I finally dropped the pan today. Upon inspection, I found some pretty big chunks of what appeared to be bearings in the oil pan. Instead of just tossing in new rod bearings and waiting on our ticking timebomb, we decided we are just going to rebuild the motor. However, one caveat: we are looking to do it on the cheap!!!! I already found a local seller on craigslist with a full 351w rebuild kit. Kit includes .040 pistons, rods, reconditioned heads, roller cam setup from a 302,full clevite bearing set, felpro gasket set, pedestal mount roller rockers, eddy performer rpm intake, etc. We are not looking to build for power or anything, just to get a reliable power plant under the hood of our Bronco. I am looking to have them assemble the entire shortblock and I will take care of the rest.
So, here are my questions: 1. What do I look for in a machine shop? What questions do I ask? if I am not looking to build power, what all do I need to have them check/do just to get us a quick(time, not power), cheap, reliable turnaround on the engine? 2. Is a .040 overbore safe on a 351w? 3. Any idea on a general cost for having this seemingly simple shortblock build? I am located about 40 miles northeast of Atlanta 4. Any georgians know of a good machine shop around the atlanta or northeast ga? Thanks for all your help guys! -Greg |
All things BOB suggested to ask about are good, you want to make sure the shop is reputable and does reliable work, but I wouldn't go looking for a speed shop, find a shop that specializes in general use engine rebuilding.
I paid $800 to have a short block assembled and another $500 to have the heads checked/fixed and the rotating assembly balanced - this included a new crank as the one in the motor could not be saved, all new bearings, new oil pump and pickup, new timing set, new pistons and rings, and an SFI approved flex plate, which was also balanced. I got a 1 year 10,000 mile warranty on the short block. I supplied a new cam, lifters, pushrods and rocker arms and did the top end install and sealing myself along with new oil pan, timing cover and intake manifold that I supplied. I would be critical of the craigslist combo and find out EXACTLY what pistons are included and discuss with my engine builder. You need to determine what compression ratio you want to end up with and the pistons are a crucial part of that equation. You also want to make sure the intake manifold matches the rest of the build though I have read that the performer rpm won't hurt a mild build. I'm not sure you'd want to run a 302 roller cam in a 351, retro fit roller lifters ain't cheap, and you probably don't want to run 302 heads as they tend to be small chambered, 58cc vs. 64cc, and will drive your compression ratio quite high; again find out EXACTLY what is in the CL kit and discuss with your builder. When you do find a builder, that comes recommended, make sure they understand you are building for reliability and service vs. performance and takes notes of what you discuss with them or get it all in writing, then post it here. Good luck with your project |
My dad's truck lost oil about 1978; filter lost seal after oil change.
Engine started knocking. Dropped pan and replaced bearings. Block has never been out of truck. Heads serviced one time; truck has almost 200,000 miles. Stlll running good today. I don't expect crank bearings chunks to harm anything. If the crank bearings are completely gone then the crank may be damaged. I would inspect crank shaft. if crank shaft ok i would just install new crank bearings. if crank is toast then a different story. Oil pump shaft broke on iron duke I4. I continued to drive it about 5 miles. Got lucky, it did not harm engine. I was all set to build a sbf in 1990. Machine shop quotes were so high that I just bought a crate engine. How did you loose oil pressure? How many miles did you drive w/o oil pressure? Any body out there experience a case where crank was not damaged and bearing pieces cause a failure after bearing change? |
Thank you everybody for all your help. I was also a little weary of the 302 cam/lifters, etc in the build.
The losing oil pressure thing is what has me stumped. We initially thought we broke the oil pump shaft as that is what it looked like once the distributor was pulled. Dropped the pan, and the shaft came out in one piece, and fits snuggly in both the pump and the distributor. Rotated the bump by hand, no problems. Pulled off the inspection plate and looks clean in there. Pulled apart the pickup, and there is minimal carbon buildup, but still a good 90%+ flowable. I guess in the short term I will drop the rod bolts and check the bearings. I pulled out my flashlight and tried to inspect the rod bearings when I was down there yesterday, but didnt see anything out of the ordinary. I will get pictures of the metal I found in the oil pan uploaded here in a little bit. Nothing extreme, maybe about 3 or 4 pea sized chunks and a few other smaller pieces. Thanks again guys! -Greg |
If it were me
I would not jump the gun.
If no rod knock then good chance crank shaft is good. The bearings may even be good. Pea sized chunk of metal...I don't follow...what kind of metal...picture please. When oil pump discharge pressure drops, the 351W will 1st starve lifters in cylinders #1 and #5 and they will start to tick; likely before any damage occurs. Pull rockers and pushrods from cyl #1 and #5 and inspect for damage. If oil pressure changes abruptly then an oil galley plug may have popped out, pump shaft snapped, oil filter plugged, oil pick-up kissed pan bottom or got plugged, pump bolts worked out, pump developed a crack...etc. Engine oil flush can cause a sludge clot and stop oil flow. I would connect a drill to pump shaft and verify oil comes out of all rocker arms (may have to rotate crank). I would connect another oil pressure gauge to verify true oil psi if rockers getting oil. Can also remove oil psi sender and connect a clear tube from sender port to valve cover. check pumped oil for air bubbles and flow rate. |
Here is a picture showing the debris I found in the oil pan(that is a dime in the upper right hand corner for size reference):
![]() 001mustang, thank you for all your help. I will try and find time to get out there in the next few days to try out your ideas. Thanks -Greg |
That IS NOT pretty.
Take a look here under Long Block:http://www.rockauto.com/catalog/raframecatalog.php This might give you an idea of what is available in a rebuilt. It wont be a 'performance' engine, but still could be the basis for a different camshaft and intake plus it is already fully rebuilt as a stocker and a warranty Dave W |
I am in no way looking for a performance build. Just an off the shelf motor than get us some good, reliable miles
Hafta find out where that metal came from...if it's from crank bearing...take a good look at the crank....clean out crank shaft galley holes before installing new bearings...verify new bearings have proper clearance...triple check torque...check oil pump for cracks, function... make sure pickup tight and clean.
The crank is going to need turned in all likelihood. I'd look for a "crank kit" that supplies you the crank already turned and the bearings that match it. Plan on having the rods checked for size.
Northern sells a budget rebuild kit, you might want to check them out. Be damn sure that you don't mix up the rod or crank bearing caps. Mark them for position now, before everything is apart. |
| 350 Budget Engine Build | dmr22 | Engine | 25 | 07-28-2010 01:40 PM |
| Machine tools for Performance Engine Shop | Double_v23 | Garage - Tools | 8 | 02-10-2008 06:26 PM |
| engine back from machine shop...what now? | awoodman | Engine | 3 | 09-02-2007 08:15 AM |
| Engine Machine Shop | rodjesseph | Engine | 0 | 02-21-2007 04:02 PM |
| 327 engine, machine shop advice? | gavinpierce | Engine | 15 | 02-16-2006 09:54 AM |
