first gen camaro bellhousing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2003, 01:13 PM
censo69's Avatar
I am looking to do a DnD t56 swap into my 69 camaro the kit I am looking at is a direct bolt in for a four speed camaro. The problem lies in that mine is currently a TH350. Does any one know where to locate a bell housing and the proper linkages that I need. The block is a 350 out of a 79 chevy 3500.Should I just spend the money on a blow proof? Also has anyone heard wether or not the year one crossmember for t56 conversion is any good. Thanks in advance
Old 08-12-2003, 05:13 PM
302 Z28's Avatar
That is just a standard aluminum bellhousing for Camarp and Nova. 4 speed or 3 speed, it doesn't matter. Do a search for the item on the below web site. If you are lucky you will find a salvage yard near you and you can look at it before you buy it.
http://www.car-part.com/
Vince
Old 08-12-2003, 05:59 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
If you plan on doing any racing with it, I would go with a blowproof. My uncle's friend only has one leg due to a piece of a clutch going through the floor board and through his leg. Just my .02
Old 08-12-2003, 11:21 PM
Hot Rod magazine (I think) did an article a couple of months ago about a new McLeod modular scattershield that could be used to put a T56 in several different cars.
Old 08-13-2003, 01:14 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I think all GM bellhouseings well work ,except the early chevy IIs.
Put a wanted ad here on hotrodders.com parts wanted,there should be a lot of clutch pedals and linkage laying around. HTH
Troy,
