First hot rod, Which front end to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 12:52 AM
Okey doke, I've been drooling over everyone's hot-rods for years now and decided i want to have a go at making my own.
I'm haggling a 302 Windsor off my big brother, and we have a leaf spring 9inch and most of the other miscellaneous parts i can get off the cars laying around our house. Im going to use an old international truck body, and maybe model A front mudguards depending on how it looks.
All that's stopping me starting my chassis is what front end I'm going to use, i want it to handle relativity well so ive been thinking about an l300 set up, I've seen a couple of builds using them and it seems pretty straight forward Id be able to get one fairly cheap as-well. im in Australia so that seems to be the only readily available front end i can think of?.
Before i go out and buy one, i thought i'd just get some advice on whether its a good idea or not , thanks
Old 12-30-2011, 04:38 AM
poncho62's Avatar
Wiki Edits: 5
I am sure none of us North Americans know what a I300 is....please explain.....maybe with a pic or 2
Old 12-30-2011, 03:28 PM
Mitsubishi L300, it mustn't be as common over there as i thought they just cut the whole front cross-member out of the van to use.
http://img683.imageshack.us/img683/4126/dsc02194.jpg
http://img683.imageshack.us/img683/8209/dsc02261.jpg
they're in nearly every hot rod i've seen so far around here.
hopefully the link worked
Old 12-30-2011, 03:39 PM
techinspector1's Avatar
Wiki Edits: 326
Doesn't look too bad for an IFS and I'm sure it works quite well if you use the factory geometry. I might trim off some excess material at the bottom of the spring bucket. It looks a little clunky.
The option would be to use a straight axle front end, such as those offered by Speedway, but the IFS will drive a lot better....
http://www.speedwaymotors.com/Street...ont-Axles.html
Old 12-30-2011, 06:12 PM
RHOPPER's Avatar
Here's another thought courtesy of your country men driving old ford trucks. Jaguar xj6. Complete subframe unbolts from the donor, disk brakes, a arms coil springs and rack and pinion. It's been used for a long time. It's cheap and it's sturdy. I've got one under my F1 pickup and I love it.
Old 12-30-2011, 06:44 PM
Wiki Edits: 326
I recently read about this from another source who claimed it works great.
Old 01-01-2012, 03:45 AM
I hadn't thought of the jag front end, I'll give some of the wreckers around here a ring to see what they've got.
I did want to use the traditional straight beam like you showed me but for the price difference kinda has me going towards the l300 or jag front now.
Also do you know of anyone who has used a bigger truck body that's been narrowed and the roof chopped to use on a hot rod?, I'm having trouble finding any pickup cabs, but i know of lots of old dodge 3 ton trucks and an old international sitting in paddocks, my plan was to narrow one of these to make it a bit smaller ? I want a rat rod kinda look to it so it wouldn't need to be perfectly styled or anything.
http://maltabuses.piwigo.com/uploads...2-aa19897b.jpg kinda like that one
thanks again for any advice
Old 01-01-2012, 10:27 AM
Wiki Edits: 326
I'd be all over one of those cabs. Maybe not cut up one as nice as the old Dodge you linked, but one of that style. I don't see where the body would have to be narrowed, it's the same width as any other truck of that era. The weight rating had to do with the suspension, not any dimensional difference in the width of the cab. I'm 100% against chopping the top because everybody does it. Monkey see, monkey do. I'd prefer to be different and leave it stock height. Looks great, less work.
Old 01-01-2012, 03:04 PM
Thats interesting, i didn't know that they were about the same size as a normal pickup cab, that should save a bit of work. I don't think I'll chop it either, Im 6 foot 7 and need all the room i can get in a car haha all i gotta do now is get the guy to sell me one for a decent price
Old 01-02-2012, 07:01 AM
You had better try out one of those old Dodge trucks before you decide... they are a little small especially for a guy as tall as you.
Maybe look for a Dodge "Pilothouse" which came on the scene here in '48 and was used until '54... they offer more legroom in a similar size.
The Jag IFS IS a good suspension to work with... lots of guys are finding out.
http://www.how-to-build-hotrods.com/f100.html
Old 01-02-2012, 03:43 PM
Any old trucks are rare around here, i don't think id have any chance of finding a reasonably priced pilothouse close by , I'll have a fair bit of time to look while i'm building the chassis though so you never know what i might pick up .
Old 01-02-2012, 08:49 PM
86GMC's Avatar
auto/truck/equipment tech.
Same for any IH before the L/R series cabs. Have a sit down first to check it out. no shortage of headroom, but can be awkward if you have long legs. My K1 always seems like i have the wheel aginst my chest and legs folded up with the stock seat and wheel. any lower on the seat it would be very uncomfortable
Old 01-18-2012, 04:10 PM
Just a bit of an update
All of the trucks i knew of, when i went to look at them they were either gone or beyond repair thanks to our constant drizzley weather.
One thing i was able to get is a short wheel base land cruiser with a 302
Windsor in it, its had heavier diffs and a lot of work done to it for only $500.
Witch got me thinking. When i find a cab of some sort it would be pretty cool to use the shorty chassis and make a 4x4 hot rod? that way I'd be able to use a cab after 1949 and not have to much trouble registering it because it would be classified as a modified shorty.
we do have an old international cab like this one that i was thinking of using if i cant find anything else
http://www.kindigit.com/images/39/sms8273.jpg i should have some photos of the actual cab this weekend
Man who would have thought finding a rooted old truck would be so damn hard
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
Front frame / Front crossmember blueprints - feedback needed lowROLLERchevy Suspension - Brakes - Steering 2 09-20-2008 05:46 PM
making front drum into front disc.....? barbiekiller Suspension - Brakes - Steering 3 05-01-2007 05:57 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
