Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First hotrod questions
Old 10-28-2012, 10:28 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Here's a link for engine sizes. I'm using a 302 and c4 in my modified. Chosen for a couple reasons.
1. Weight
2. Distributor in front.
Chevy is about 2 inches shorter in length if you use a short water pump but the rear mount distributor causes clearance issues with the firewall and you'll likely need to move the motor ahead for clearance.
Other thing to watch for on 302 is oil filter placement on drivers side front. Depending on what steering you use you might need room around the filter.
Popular American V8 Engine Dimensions
