First of many mistakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2010, 05:09 AM
Registered Novice
OK, I have filled-in a few blemishes on the tank and fender and I did it in a couple of stages.
I presume the different colours showing through on the tank (pic attached) is because I mixed different proportions of hardener at each filling stage.
Will this "bleed" show through at a later stage?
It still needs priming yet and I hope that covers it.
Also as I am a complete novice at this; do I need to cover ALL of the metal, or will the two-part primer take care of that?
Old 06-01-2010, 05:31 AM
milo's Avatar
point on positive
There will be those who exclaim that a particular primer will cover that no problem...that said if it were me I would float another "skim"coat of a two part putty and not trust any primer to take it from here so to speak.. The picture shows you have been putting in the hours and effort and are real close and maybe you could call it primer time but first read this one anyway...
http://www.a2zautoforums.com/showthread.php?t=936
P.S. give those high spots where the metal is coming through a gental tap with a pointy hammer ...
http://www.youtube.com/Milogarage#p/u/21/Vc8jwVmQAsY
Old 06-01-2010, 05:59 AM
Registered Novice
Thanx for the tip Milo.
The link in your response had some good pointers for a novice like me.
Thanx again for your time.
Old 06-01-2010, 06:09 AM
milo's Avatar
point on positive
Your way welcome ..
Heres yet another link that will help convince you to hang in just a couple more hours with a 2 part skim coat of a glazing putty ..
http://www.a2zautoforums.com/showthread.php?t=3456
Your real close take the time...
Old 06-01-2010, 08:37 AM
I would go with an application of POLYESTER PRIMER if needs another coat of putty. The polyester primer will fill just as much as a skim coat of polyester putty but be WAY easier to sand being it won't be spread out like a wedding cake icing.
Old 06-01-2010, 09:42 PM
Registered Novice
Thanx for the tips guys,
I'm goina lay a coat of poly primer on it (2 if I think it needs it) and sand that.
Being a novice I found it difficult enough to lay the bondo with a flat spreader over all the round curvy bits. I'm goina do the primer today after work, I will probably start a new thread after that as I'm sure to **** it up somehow
Worst feeling ever BMM Hotrodders' Lounge 14 05-10-2008 06:20 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 11:21 PM
topless roadster oldskoolmopar49 Hotrodding Basics 2 01-07-2006 06:22 AM
Learn from my mistakes Derkyb Body - Exterior 9 07-13-2005 06:57 PM
Priming Mistakes 70chevy Body - Exterior 8 04-27-2004 01:54 PM
