First Motor Build - a Mopar 451 Stroker? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2009, 06:54 AM
Last journal entry: Rear End Disassembly
Thanks to a recent post by F-Bird'88, I've decided to debate building a Mopar 451 Stoker Motor for my studebaker project. Thank you for the info F-Bird, I wanted to build on my own, and now it seems that I can find an economical way to build a powerful motor.
I would like some input from you experienced rodders. I've never built a motor from the ground up. I've torn into and repaired top ends on motorbikes/muscle cars, but never tinkered with setting bearing clearances, and everything necessary to do a build. However, being a mechanical engineer, I'm quite meticulous and research and read a TON to make sure a job is done correctly.
So my questions to you: How did your first engine build turn out? Is it a bad idea to make my first engine build a stroker? And most importantly, are there a lot of minor details (small o-rings, tricks of the experienced trade) which a "How-To" book would leave out which you rodders would know to look for just because of previous experience?
I would like to purchase "How To Rebuild Big Block Mopar Engines", among a couple other books and read before I start.
Lastly, I found a 400 block for sale about 5hrs away. It has been sitting for quite some time. How often are old blocks cracked? Are there any areas of the block which commonly crack and would be easy to pick out prior to purchase?
THANK YOU!!!
Old 04-03-2009, 03:04 PM
DoubleVision's Avatar
If it were I, I wouldn`t try to do any fancy stroker combo for my first build, I would go with the simple route of building a basic 440 or which ever cubic inches you desire that was avalible from the factory. These engines are easy to build and this is how you learn engine building skills by starting out easy.
Advice I can give is make sure the bores are clean. Honing impregnates the grit in the cylinder wall and it must be scrubbed to be gotten out. I mention this as it`s what many new builders neglect to do. With a paper towl and WD40 with a quick wipe will tell you if the bores clean. if you see gray on the paper towel it`s not clean.
Old 04-03-2009, 03:57 PM
cope's Avatar
go to mopartech.net these guys no there s*it they will tell u straight up without being a as* about it.
they will help u build your first engine step by step all the way. u will see me on there as i am a mopar guy too hope to see u there l8ter cope
Old 04-06-2009, 10:48 AM
DoubleVision: And what would be your reasoning for not doing a stroker for a first build? Perhaps the amount of money with a possibility of not doing it right? Otherwise, as long as all components are layed out properly, the majority of machine work in the block will be done in shop.
Cope: I will definitely check that out. Thanks.
Old 04-06-2009, 12:16 PM
i'm building a 541 now too. i don't see a 451 mopar being that big of a deal for a first build. the crank gets all the grinding. all he has to do is check for clearance between the rods, counterweights, & the block during mock up. my 400 block needed nothing, & that was using h beam rods.
Old 04-06-2009, 12:25 PM
Banned
building engines is easy as long as you keep it clean, have good tools, and take your time.
using a book is a great way to start and many provide checklists to use as you go.
CLEANLINESS IS GODLINESS, you should be able to eat off the floor in your assembly area. I'm not joking, its very important, ask anyone who's ruined a crank and a set of bearing on startup.
Old 04-06-2009, 06:09 PM
Cost has nothing to do with it. It has to do with something called Experience, which is something there is no subtitute for.
Old 04-06-2009, 06:50 PM
all he needs is someone to help him. i wouldn't advise him to build a 434 stroker small block Chevy, but a 451 mopar is basically straight forward. tell the crank grinder to turn the 440 mains down to the 400 size. the counter weights will also need trimmed down to 7.25 to aid in balancing. pretty much the crank grinder does all the work on this particular stroker combination. everything else will go together like a basic rebuild. he will need no more help with this than he would a 440.
Old 04-07-2009, 07:09 AM
and that was my impression as well. 440source.com sells pre-machined and balanced forged rotating assemblies. they specialize in turning new 440 cranks down to fit inside a 400 block (for journals and counterweights).
a machine shop would simply machine a 400 block accordingly to specifications, and the stroker assembly should bolt in place (outside of small areas in the block which may need to be ground for rod clearance???)
DoubleVision, I understand your concern, and I feel the same way, but I don't see a major difference in experience to build a stroker 451 vs. a stock motor. Given the one scary area being the large amount of money invested hoping the first build went well.
As I may be picking up a 400 block soon, any suggestions on checking for cracks?
Old 04-07-2009, 07:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 71gtx
...any suggestions on checking for cracks?
A good visual check w/bright light to start with, if you find nothing (webs, head bolt to bore or water jacket, cylinder, etc.) haul it down to the machine shop for a magnaflux check.
Only costs a few dollars, and if you're going to have them do work on it, might be a freebie.
Old 05-01-2009, 08:51 PM
i'm a big block mopar freak. i have 10 big block mopar engines in my garages. the 400 is a b block engine/ not that good of a block. intake and dist is different from b block and rb block. you will be better off to start with a 440 or 413 block.the early 361,and later 400 are b block,some 383 are b block. all 413,426,440 are a raised block(rb) some 383 are rb block too. a visual check for cracks is great, but you need to take the block to a machine shop to get checked out. rule of thumb is to buy a block very cheap that way your not out alot of money. my $.02 is to start with a 440 or 413 and you don't need to stroke an engine for horsepower.
new and need help building 383 stroker enygma500 Engine 10 02-10-2013 01:24 PM
Look for info an building a 383 stroker Cllmewish Hotrodding Basics 16 12-28-2012 03:31 AM
Building a 383 stroker jchav62 Engine 9 12-15-2005 08:28 PM
383 Stroker Ozz1967 Engine 11 11-04-2005 06:08 AM
building a 383 stroker johny500 Engine 2 12-14-2003 08:39 PM
