First Paint Job: What paint for this color? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 07:35 AM
I am going to be painting my first car. It is a complete paint job and will be done in one of the newer colors. It is the 0580 code of the Gold Rush Mica from Toyota Scion. I have included a picture of the color on an attachment to this thread.
Not sure what line to use. I have used the PPG line so far with the DP40LF epoxy followed by the Shopline 2K spray filler primer. I have blocked it once and now resprayed and ready for the final sanding before epoxy sealer.
Question is:
What line is best for economy and for this color? I don't mind using SPI clear if it is best with PPG Deltron Paint etc. I just want to know a few options to consider. I have read a lot on here but, boy, as a first timer it gets confusing. I am not worried about actually spraying it, I am worried about picking a wrong combination or spending a lot more money than necessary.
Can you please help?
I want am ready to get started on this as soon as possible.
PM's are welcome. I understand these type's of questions can be controversial.
SAM
Old 04-28-2009, 05:14 AM
What no opinions on this? I would really like to hear what combinations work. The difference could be hundreds of dollars...so if anyone could help I would greatly appreciate it.
SAM
Old 05-01-2009, 01:36 AM
milo's Avatar
point on positive
Doesn't matter if your just doing the one car... The reason a lot of folks stick with one paint line or another is it's easier to learn how one act's/sprays and the left overs can be used to tint and make sealers/pre-base surfaces for future projects etc..
There was a time you had to worry weather it was lacquer or enamel you were painting over but not anymore...It may seem pricey today but a repair or a project or 2 down the line and the decision to go with the best from the beginning actually saves /makes dough...
Dbc at 70 degrees with 1870 reducer with your clear of choice would be easiest to nurse along and get a good result for what it sounds like your asking though.
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
Why paint my f-150 the same old original Color? satexasf150 Body - Exterior 9 03-06-2006 10:24 PM
matching paint color to powdercoat color powerrodsmike Body - Exterior 4 12-11-2005 07:01 PM
easy paint job info needed pjd Body - Exterior 1 08-09-2005 10:30 AM
