Hello all, I'm new tonight with a real question. Thanks in advance.
I purchased a 426 hemi that the engine builder put Pete Jackson timing gears in. To lub the gears he drilled an 1/8 hole in the oil passage right behind the gears to "spray" on them. To compensate for the pressure drop he installed a high volume oil pump. The pressure dropped 10-12 psi at idle but "ran" 90 cold and 45-50 hot. I did not like this so I installed a .060 carb. jet to reduce the hole dia. but it didn't do as much as I liked. It only gave me about 5 psi better. Question: should the gears get enough oil the traditional way that the "old" chain would have gotten oiled. I want to plug the hole and use all my pressure. Note: car was built in Miss. There is no "bringing it back for him to fix".
