First post, info needed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2007, 03:43 PM
I have a 1956 chev 1300 (longbox 1/2 ton)
I have purchased Flatout engineering corvette crossmember and rear install kit for C4 suspension, I have a clean 93 c4 front and rear susp.
I have arranged to purchase from a friend 1983 c10 suburban rust bucket with a newer gm goodwrench 350/auto. Question is what tranny is in the Suburban (he is overseas) and what would be required to use his tilt column??
Spent all my money on the first 3 parts?
Thanx.
Apparently the tranny is original and the shift window indicates 3 speed automatic "overdrive"
Old 02-10-2007, 09:11 PM
brian0605's Avatar
mostly confused
Last journal entry:
200r4??? can you tell the shape of the pan??? that is the easiest way to identify. As for the column never done that convert before. Good luck I know someone out there has. Brian
Old 02-10-2007, 09:58 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Take a look at this thread:
55 to 59 chevy truck owners
Old 02-11-2007, 12:14 PM
Thanx guys that link was great.....looks like I have 700r in the donor truck.
Antone have anytips on using a c10 tilt column in a 56 chev half ton??
Cheers T
Old 02-11-2007, 01:10 PM
Chopt 48's Avatar
It sounds like you are in business.
I'd pull the column out of the doner truck and then start measuring. The big rub may be with the ignition switch. some guys like them on the column some don't.
If you still have the original column in the 56 measure the distance the rim is from the dash and measure how far the column sticks up from the dash.
From experience if the wheel isn't in the right position the truck will be uncomfortable to drive over any distance.
Will the shift lever clear the dash? Basically you need to check to see how it works on both ends as you have to have the lever for the shifter have room to work on the bottom end.
Without going to the aftermarket columns, a column out of an 80 something Chevy van still has the ign switch in the dash and is pretty clean looking, it also has the indicator on the column. Not hard to find in the wrecking yards and you can probably craigslist your column for enough to pick one up. Those were the hotlick thing to use before the aftermarket guys came into play.
It sounds like you have the start of one nice truck going, It's time to start a journal to keep us updated on progress
Head info needed gilby246 Engine 2 10-08-2006 09:12 AM
Head info needed..please gilby246 Engine 2 09-27-2006 07:25 PM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 07:15 PM
Machining Info. Needed GoneNova/406 Engine 10 06-22-2006 08:22 PM
Paint info needed....please Steve UK Body - Exterior 5 02-03-2006 05:07 PM
