It looks like a really bad case of fisheye. Try using a few drops of fisheye eliminator in the finish paint. Fisheye is caused by contamination, but hard to say where you are getting it from, seeing that you are taking so many precautions already. You said you have changed all the filters. Are you by any chance using an inline oiler/water filter? If you are, then there's the problem. You use an oiler through the lines to lubricate the tools, but some guys forget that when you hook up a paint gun, you will still get drops of oil through the lines.
yes changed alot of things, really hard to find out where im going wrong,they are just filters/traps, i know the ones you mean that oil, not using them. hmm, could it be spraying temperture? it has been very cold over here lately..
thanks for response |
Hey neil
Didn't post this on MR2OC then ;p Have you recently started using waterbased basecoat? Reason I ask is I was painting a couple of bumpers in solvent base but run out of paint doh! Had a litre of the same colour in waterbased so thought I'd stick that on I got a very similar reaction to what you're experiencing i assumed that the evaporating solvent separated the waterbased paint. Won't be doing that again ![]() I was just wondering if you hadn't let the basecoat fully cure before applying the clear whether you'd get a similar problem. Jez. |
I know this first hand, it happened to me a couple of years ago. Clean wiping cloths stored in a metal cabinet on an upper shelf while a case of motor oil was stored on the bottom shelf. Never again. |
| Weird problem in clear coat. | BMM | Body - Exterior | 6 | 05-09-2008 01:27 AM |
| cloudy clear problem >>.. | ejbalboa | Body - Exterior | 3 | 07-15-2007 08:46 AM |
