First start Chevy SB - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2009, 02:34 AM
Hey. Im in progress to start my engine and have a new cam in it. I also have a new HEI distr. and I want the engine to start on first try so I can rev it up for the cam to be properly breaked in. Can you help me get the timing right with the engine off? With points I allways turned the crank to what advance I wanted and with a bulb on the coil turned the distr. till the bulb flashed. How do I do that with a HEI?
/ Krille
Old 06-09-2009, 06:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can do the same basic thing by using a spark plug checker, a timing light or a spark plug hooked to #1 plug wire.
Key "on", turn the distributor till you get a spark, just like you used to do w/the points set-up.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
SB Chevy 350 misfiring at idle... Cobra9117 Engine 3 08-10-2011 06:50 PM
HEI Chevy wont start if battery is low at all ? Berg Engine 20 07-16-2008 09:59 AM
chevy kick-back upon start up coolP11 Engine 2 05-20-2006 10:35 PM
400 SB Chevy onebadmerc Engine 2 03-24-2003 03:11 AM
