Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First Start Up Problems
  #17 (permalink)
Old 05-22-2010, 03:08 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by 1974blackz28
A local mechanic said I can let the car Idle for 5 minutes while I adjust the timing then do the cam break in is this true?
Just so you know, there is no pressure lubrication to lube the cam and lifters. All they get is what's thrown off the crank and rods and some dripping off the bottom of the cylinders and maybe some "oil fog" from the air in the crankcase. When you are idling the motor, the crank isn't turning fast enough to provide enough oil to be splashed onto the cam and lifters.
Please read post #11 on this thread for a guideline to camshaft install and break-in.....
Engine/Cam Breakin
