First thing to break in these GM 7.5 rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2014, 04:34 PM
what is the first thing to break in these 7.5 rears, the ring gear or the pinon. i'm souping up a monte with one of these rears and have just bought a power trax posi for it but haven't put it in. do you think i sould replace the axles to or waste of money. i put a posi in because this car was so dangeroue in curves, wanted to spin real easy.
Old 01-28-2014, 05:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders
I moved your question post to a new thread
Please do not ask your new question in an old thread. Members often dont see your new question.
Old 01-28-2014, 05:24 PM
BOBCRMAN@aol.com's Avatar
Those axles break with regularity
Old 01-28-2014, 06:13 PM
big gear head's Avatar
High Performance Rear Ends
There are many things that break in the 7.5 rear ends. I've seen the ring and pinion break, differential gears and axles. It's just a light weight rear end that was not designed for high performance use. I would recommend saving some money for a Quick Performance 9 inch Ford housing and axle package and then get a good used chunk to go in it.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (01-29-2014)
Old 01-29-2014, 06:16 AM
vinniekq2's Avatar
tires spin or car?
posi rear ends do not help cornering,its the opposite. You need posi for acceleration,, but a posi tends to push in corners until such time as it breaks traction and causes over steer
The Following User Says Thank You to vinniekq2 For This Useful Post:
AutoGear (01-29-2014)
Old 01-29-2014, 11:08 AM
that mekes it fun and perdictable thats why cup cars use lockers not posis.
Old 01-29-2014, 11:14 AM
i mispoke it's a locker i installed not a posi.
Old 01-30-2014, 10:08 AM
malc's Avatar
Living At The Speed Of Life
I noticed my 2 carrier doesn´t need to have the ring gear pressed on,
very little flange for it, the bolts are doing all the work.
Two things that can be done is swap to studs on the diff bearings and
get a diff cover with bearing supports.
Old 01-30-2014, 12:24 PM
i've got the support but if you put studs in won't n it tighten up the bearing clearance. i know it will on the mains in a eng. with bad, bad results
Old 01-30-2014, 12:43 PM
malc's Avatar
Dunno it´s a fix recommended by Randy of Randy´s Ring & Pinion.
Old 01-30-2014, 12:55 PM
i'll give randy a call and get his avice.
Old 01-30-2014, 01:14 PM
malc's Avatar
This is the book I got the info from,
Differentials: Identification, Restoration & Repair Differentials: Identification, Restoration & Repair
- 2nd Edition Covers basic differential info, differential specifics, tips & how to's, and DIY rebuilding,
Jim Allen & Randy Lyman
Old 01-30-2014, 02:19 PM
thanks for the info. i'll give it a read
Old 01-30-2014, 02:35 PM
this monte will never see slicks or even stickey tires. i just want it to be trustworthy behind a 400 hp eng. one guy told me the tranny would break long before the rear. 200-r4 with a g.n. converter. i don't know anything about the internals. the guy i bought it fromm swears i'ts got a 700 in it. he also said the crank in the eng. wasn't broke. said it couldn't run like that. i put 400 miles on it before i decided to crate motor it.bam crank came out in 2 pieces.rebuilt g.m. eng. with only 31,000 miles pur. over 3 years ago. naturly no refund or help on the purchase price of ten bills.
Old 01-30-2014, 03:14 PM
vinniekq2's Avatar
10 Gs for a stock engine?
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 04:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Rear disk break problems on camaro Chevy Thunder2 Suspension - Brakes - Steering 5 04-28-2004 10:48 PM
