Hi,
The 3.480 is the stock stroke, the 3.750 (400ci crank/stroke) is for stroking the 350ci to 383ci. Rich |
Hello Terry, for improving yours and other's education a bit, I'll expand on this subject. Small Block Chevy motors were built with 3 different crankshaft journal sizes through their production run. Refer to the following (which I copied from the Mortec site). From 1955 up through 1967, the Gen I small journal sizes were used. 1968-up small blocks up through the 350 size motor used the medium journals. When the 400 small block was introduced, it used the large journal size for its entire production run. Your crankshaft would be the medium journal size, with a stroke of 3.48".
These crankshafts can be had in either cast or forged configuration. Cast is cheaper to buy and will perform admirably in a street/strip type motor where the motor is run at limited rpm's. Forged is more money and generally used in a dedicated competition-type motor, although there are fellows who build street motors who insist on using a forged crank. The reciprocating assembly (crankshaft, rods and pistons) in your motor is balanced internally. There are other small block Chevy motors, like the 400, which are balanced externally with the use of eccentric weights on the harmonic damper/balancer and the automatic transmission flexplate/standard transmission flywheel. Also, your cylinder block uses a 2-piece type rear main bearing seal. Later small blocks used a 1-piece rear seal arrangement to help prevent oil leaks at the rear of the motor. Here's an example of a replacement crankshaft manufactured by Scat that would work well for you..... http://www.summitracing.com/parts/SCA-910442/ Gen.I, "Small Journal" 265...Mains-2.30"-Rods-2.00" 283...Mains-2.30"-Rods-2.00" 302...Mains-2.30"-Rods-2.00" 327...Mains-2.30"-Rods-2.00" Gen.I, "Medium Journal", includes "Vortec" 305 and 350 thru '98 262...Mains-2.45"-Rods-2.10" 267...Mains-2.45"-Rods-2.10" 302...Mains-2.45"-Rods-2.10" 305...Mains-2.45"-Rods-2.10" 307...Mains-2.45"-Rods-2.10" 327...Mains-2.45"-Rods-2.10" 350...Mains-2.45"-Rods-2.10" Gen.I, "Large Journal" 400...Mains-2.65"-rods-2.10" |
Thanks Guys!!
Thanks for the quick response. Man that was fast. So if I wanted to change my 350 to a 383 all I need to do is change the crankshaft? Not that I plan on it, but what about the rest of the internals? And the heads? Is there a kit that includes pistons, rods the crankshaft and bearings and higher compression heads?
Hi,
There are stroker kits, crank, rods, pistons, block needs to be clearance checked for the crank & ground accordantly, the cam clearance needs to be checked also, & bored to make it 383ci Heads you'll want a set that will complement the rest of the build along with the cam, if you click on the search button at the top of the page & type 383 stroker you'll get a lot of info on this subject. Rich |
Thanks Rich, for general educational purpose I'll do that. I mainly just wanted to be sure and get the right crankshaft to replace the stock 3.480 that I messed up. And while I'm at it replace the piston rod bearings and main bearings and engine mounts while I have the engine out of the car. I will also clean up and restore the engine compartment. Do you know if it's neccessary to remove the radiator for clearance to remove the engine?
Hi,
The last corvette I changed engines in was a 67, SB out BB in the other one was a 68 BB out & it was wrecked, the one I have now is an 88, I removed the rad on the 67,& the 68, the one I have now looks as if it needs to be removed, but for your's I don't know, I would probably remove it & have it flow tested just because of Murphy's law. Good luck, Rich PS You might try at corvette forms |
What if the motor swings on the cable/chain and the water pump pulley takes a chunk out of the radiator while you're pulling the motor???? Ask me why I ask!!!
You are so right, why did I even ask. This is the first time I pull an engine. The most I've ever done was re-ring the pistons last year with the engine in the car. I will wind up removing everything I can get to while the engine is out and refurbishing or replacing it anyway. |
Hi,
I'm looking to have mine painted, my sister picked a color some kind of green, I've asked other people how it (color) looked, told it's very nice I personally have no idea I'm color blind, also mine is for the lazy people 700R4. Rich |
engine separation
I have everything removed from the front of my engine and ready for extraction. I have an engine hoist and rigging and an engine stand. Can you direct me to instructions to show me how to remove the engine but not the transmission? |
I can see how the damper could have been damaged- but to bend the crank by a one-hit w/the floor jack? I'm doubting the hell out of it, personally. One stroke of a floor jack (unless you use a NASCAR-type jack) would barely compress the rubber of the damper- let alone well and truly bend the crank snout. |
X2.......I was just wondering??!! Cranks bend THAT ez?! 6sally6 |
Shameful as I am to admit this, but I've jacked an entire SBC engine up off it's mounts- by the damper- long enough to wedge wood blocks to hold it up to remove the pan (pan was cast Al- I didn't want to crack IT lol). Much younger, much more "hurried" than I am nowadays, but I did do it, just the same. :
| Long time lurker | kroozer48 | Introduce Yourself | 2 | 09-27-2009 09:57 PM |
| 1st time engine rebuild problems. | J77 | Engine | 8 | 06-30-2008 04:43 PM |
| finally time to put my indian back together | bullheimer | Hotrodders' Lounge | 8 | 03-03-2004 07:23 PM |
