First time Ford builder - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-24-2013, 06:15 AM
Currently rebuilding a 55 Customline. Plan on installing a 5.0L FI w/ AOD trans. Any help with info on this swap would be greatly appreciated!
Old 03-24-2013, 06:31 AM
Irelands child's Avatar
Welcome aboard - photos are always welcome of your project.
Nice project, convert the '55 to 12V, weld in some motor mount brackets, drop the engine in that cavern of an engine compartment and go cruising. Oh and upgrade that sloppy OEM suspension and replace the tender rear end with at least a minimum of an 8" though an 8.8" or 9" is better then add better brakes on all 4 corners. Other then that, ask lots of questions if you have them, and someone will have a logical answer.
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
55converted (03-26-2013)
First time 350 builder need help! shanerocks Engine 41 05-06-2010 09:01 AM
first time builder pike master Introduce Yourself 2 09-01-2009 09:17 PM
first time builder pike master Engine 17 09-01-2009 01:44 PM
First time builder MitchJKG Introduce Yourself 2 09-05-2007 10:07 PM
First Time Builder BUCK GK Introduce Yourself 1 03-31-2006 11:01 AM
