First time Head Porting. How am I doing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 06:04 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey Everyone. I have a set of '882's from a 350 that I figured would be a good set of heads to start grinding away on. I am gonna work on the short side radius, bowl blend, gasket match the intake, and tear drop the valve guide boss. Here are some pics of where I am at now. All criticism is accepted!
I will post more as I progress.
Old 01-31-2010, 06:31 PM
automotive breath's Avatar
One of the most important things to learn about porting is to size the bowl
and throat. If you look at this picture there is a margin left just after the
valve seat in the 12 o clock to the 4 o clock position. After that material was
removed almost to the seat. The margin should extend all the way around
the throat, the throat should be ~87% of the valve diameter.
Old 01-31-2010, 06:35 PM
Look like a good start! Just don't damage something important and try to keep them all as similar as you can. Look up pictures from people who have hit the water jacket on that head and make sure you leave plenty of material there...
Old 01-31-2010, 06:39 PM
Listen and Learn
Wiki Edits: 7
Thanks automotive breath. I will go around and clean that area up so its more even. I will also go in with a dial caliper and make sure I stay under 87% of the valve size.
Old 01-31-2010, 06:40 PM
F-BIRD'88's Avatar
Yada Yada Yada
You want to carve two strong airflow flow paths around the guide boss.
With a bias on the common wall side.
Raise the roof of the port from the entry all the way to the bowl guide boss zone. Do not lower the floor of the port other than to clean up the rough cast. Open up the pushrod pinch width. Port match the entry to a felpro 1205 gasket.
This is a pic of a finished 305 head but the job is the same.
Old 01-31-2010, 07:00 PM
Listen to what f-bird is saying, there is not enough good information
written about shaping the area at the guide.
Here's a picture of a set of heads I'm using a snap gauge to begin to size the
bowls. Notice how I left plenty of material between the throat and the seat,
in your picture you already cut too much here.
Old 01-31-2010, 07:01 PM
Listen and Learn
Wiki Edits: 7
F-bird - wow nice job on those guides. I will do as you showed on yours and make the two paths next to the guide where the air can flow. I will also get a set of the 1205 fel pro intake gaskets. I can't believe how much bigger the ports are on those gaskets. Is that a pic of those 416 heads?
I will make sure to be more careful in this area. I checked with a caliper and im at about 88%-89% now. I will buy an inside telescoping gauge so I can measure it more accurately.
Old 01-31-2010, 08:08 PM
Think of it this way, its easy to remove more material, difficult to put it back.
With that in mind target something smaller than what you want to end up with
like 85% at the throat and 92% in the bowl.
What you are doing is sizing and shaping an orifice, preparing the air to flow
around the valve, the primary restriction in the port. This is the most
important thing to learn about porting.
Next concentrate on the push rod pinch and the short turn.
Old 02-02-2010, 06:52 AM
Listen and Learn
Wiki Edits: 7
When shaping the valve guide area how much material should I leave around the valve guides? They are bronze I imagine there is a certain amount that should remain there.
Old 02-02-2010, 08:44 AM
good job.
the bowl smoothing is the best back for the buck. I would stop there, as the other stuff doesn't add nearly as much.
Old 02-02-2010, 09:06 AM
How fast is fast enough?
the object isn't to take out as much material as possible, but to smooth what is there. You don't need to grind on every surface, you already went to deep on most of it. Use the carbide bit to take off the big deges and use a 60 grit cartridge roll to bring it all together. When you're starting out less is more.
Old 02-02-2010, 09:21 AM
Listen and Learn
Wiki Edits: 7
yea my bad I got a little too happy with the grinder.
Old 02-02-2010, 09:25 AM
read this.
http://www.chevyhiperformance.com/te...ing/index.html
Old 02-02-2010, 09:38 AM
Listen and Learn
Wiki Edits: 7
Originally Posted by 454C10
thats a good article. bookmarked it
Old 02-02-2010, 09:47 AM
hey, you're working on 882 heads, its not like you made them any worse.
If you want you can also try your hand at epoxy, on race heads its common to use epoxy to fill in certian areas, you need to use the right kind of epoxy and sealant but you could try it.
Head Porting 428BIRD Engine 12 02-01-2010 04:29 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
Vortec head porting article 4015c Engine 1 11-27-2002 10:06 PM
Head porting and polishing MonteCrl Engine 1 10-22-2002 03:40 PM
