-   -   First time painting a car - noobie questions (http://www.hotrodders.com/forum/first-time-painting-car-noobie-questions-186078.html)
kylex 10-15-2010 10:11 PM
I'm attempting to paint a car for the first time.
I've just finished stripping the car to the metal, and already I'm a little confused.
Do I do the body filler on the bare metal before I use my epoxy primer or do I prime first?
If I prime first, and then use filler, do I need to prime over again? Thanks for any clarification!
001mustang 10-15-2010 11:03 PM
You can put filler on bare metal or on epoxy primer. If you work slow I would epoxy the freshly sanded/cleaned metal first to minimize flash rust. Epoxy has a respray window; window exceeded you must scuff it first. If you put filler over bare metal always sand and clean metal just before applying filler.
kylex 10-16-2010 02:04 PM
Before I put on the epoxy primer, what are the steps to cleaning the bare metal? What should I use?
001mustang 10-16-2010 03:28 PM
A common mistake is to spray before wax and grease remover has flashed off.
Many ways to clean.
I like to use laundry detergent, dish washing soap, wax and grease remover, acid etch/rinse and finally ammonia/water.
