Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time patch welding
Old 12-06-2011, 10:19 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Yes the pin holes can be a issue.A lot depends on where you live and if car will be driven in bad weather. If you live in a dry state not that big of a deal. Best way is to sand blast with a small hand sand blaster over your weld before you apply any filler to it.If you have the fender off you can sand blast the back side of your welded patch epoxy prime then seal weld area with seam sealer and undercoat.
