First time patch welding
I have welded my first patch panel on a lower fender piece that was rotted out. I was having problems with my MIG welder using .30 wire and keeping it from burning through the panels. I carefully patched this panel (sorry I know its not the right way) but Im afarid that I might of left pinholes in between the spots. When I grounded the edges down I noticed that many of these pinholes where covered up by the grinding but I know theres still some left. My question is If I shoot a couple coats of Epoxy primer will it seal these pinholes? also there seems to be some dark burnmarks in between the tiny seems it it important to clear this out before applying the epoxy? if so what do you guys recommend?
http://i1080.photobucket.com/albums/...PatchPanel.jpg |
i would go get some 023/024 wire
it will be easier than the 030 wire and go back over anywhere you think there is a hole or a low spot keep it up, looks good |
Yes the pin holes can be a issue.A lot depends on where you live and if car will be driven in bad weather. If you live in a dry state not that big of a deal. Best way is to sand blast with a small hand sand blaster over your weld before you apply any filler to it.If you have the fender off you can sand blast the back side of your welded patch epoxy prime then seal weld area with seam sealer and undercoat.
X2 on the seam sealer,can help tidy up the welded area aswell!
Once again your being too hard on yourself (a sign of a good craftsman) Your patch looks fine. all you need is a couple pointers..
Try putting a drop light behind the work to find the pinholes then blast them with your welder. The blue spots are metal ground too thin and getting overheated to fix this just get your pick hammer or a punch and counter sink the spot then weld it up...piece a cake... |
I figured I was over analyzing the situation.. I was thinking that these tiny, if any, pinholes can just be covered with a couple layers of Epoxy Primer, filler, then the primers. Doesnt see how filling with figerglass resin first willbe any help. If water gets in and starts rusting the metal the resin will separate from the metal. DBM I do see how I can just blast small pinholes with the welder but Im afraid to burn through again.. Ive had a hell of a time keeping not burning through. Im hoping that problem is that Im using too big of wire guage.. using .30 without gas. Ive lowered it as far as I can go but still cannot get it to flow smoothly. My next invested is a C-25 gas tank.. Do you think gas and using smaller guage will make that big a difference? |
if you are using 030 flux core now, you will feel like a pro with the smaller stuff |
Thanks Matt.. Looks like I will be investing in a tank and regulators..
I was hoping that it would make a big difference. By the way I love your 37 coupe.. Ive been looking for a 37 for some time looks like Im gonna settle for a 40 coupe.. |
I believe so.. I have a Millermatic 140 It does have a gas inlet in the back.
I dont weld very often how fast does a tank of c20 last? should a buy a small 2- ft tall one or a 4-5 foot one? Do they expire? |
I don't weld all that often either. I just use the little scuba sized one. Just remember to turn the gas off when you're done. I forgot to turn mine off once and about four months later I needed to weld something and the tank was empty, and of course, the valve was wide open.
| welding in patch panels need help | cutthroatkid | Body - Exterior | 15 | 12-13-2011 09:53 AM |
| Welding in a patch panel | slingslingbinks | Body - Exterior | 16 | 01-07-2011 11:39 AM |
| Question on welding patch panels? | sled51merc | Body - Exterior | 39 | 01-30-2005 11:56 AM |
| Could Mig welding patch fry the computer? | asennad | Body - Exterior | 3 | 04-16-2003 06:32 PM |
| Welding in patch panels | Maverick | Body - Exterior | 15 | 02-01-2003 05:32 PM |
