Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #35 (permalink)
Old 01-05-2013, 06:49 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Leave the stock studs alone. They do not pull out like the stock studs on the old heads do.
They are fine as is for most hi perf street applcations. even with high perf springs.
Just use a self guided style rocker arm ( stock or aftermarket)
The risk of breaking the the stud boss by trying to pull them out exceeds the
preceived benefit of a screw in stud.
Again, these stock pressed in studs do not cause the issues that the old heads did.
LEAVE THE STUDS ALONE
What cam and rockers are you using. You are probabily getting all carried away for a bunch of nothing.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
Camaro_Nut2001 (01-05-2013)
