Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #39 (permalink)
Old 01-06-2013, 12:24 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Concentrate on getting the compression ratio correct.
a clean up on the as cast vortec ports is fine for this cam.
See the funnel in the intake port just under the valve. Leave it alone when using that cam.
It has a purpose.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
Camaro_Nut2001 (01-06-2013)
