Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #40 (permalink)
Old 01-06-2013, 01:29 AM
Camaro_Nut2001's Avatar
Camaro_Nut2001 Camaro_Nut2001 is offline
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by F-BIRD'88 View Post
That cam runs just fine with all stock vortec head parts.
With small cams like that you do not need to get carried away with porting stock vortec heads.
Most of the flow gain from porting is found at higher .450++ valve lift.
You can clean up the ports to good effect but do not attempt to make race ports. its not nessessary and will not help.
That cam works very well with vortec heads on a 350 and 10:1cr, performer rpm intake and 750 holley/edelbrock carb.
375hp 400+ ftlbs torque.
Thank you for the info on my combo, I actually picked this cam when I was gonna run self ported 305 heads, lol. Like I said at the first of this thread, this motor is goin in my '88 S10 with a th350 or th400, haven't decided yet, which will be used as my daily driver/sleeper truck.
