Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #41 (permalink)
Old 01-06-2013, 12:36 AM
Camaro_Nut2001's Avatar
Camaro_Nut2001 Camaro_Nut2001 is offline
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by F-BIRD'88 View Post
Concentrate on getting the compression ratio correct.
a clean up on the as cast vortec ports is fine for this cam.
See the funnel in the intake port just under the valve. Leave it alone when using that cam.
It has a purpose.
Yes, I have yet to measure my quench so I can order my head gaskets. I'm going to go with long tube headers, 2 1/2" exhaust with these mufflers Dynomax Super Turbo Mufflers 17733 - SummitRacing.com and this converter Hughes Performance XTM Heavy-Duty Towing Series Torque Converters GM11XTM - SummitRacing.com.
